DivX scaling on Samsung HD950
Discussion in 'Blu-ray & DVD Players & Recorders' started by Caimbeul, Oct 26, 2005.
  1. Caimbeul
    Caimbeul
    Jun 7, 2005
    734
    Kent
    +25
    I have the 950 and when playing back various movie formats from DVD eg: DivX, Mpg AVI etc I have noticed that the scaling make the image too big so that I am missing some picture from all four sides (similar to what you would lose watching a 16:9 image on a 4:3 TV) this is very anouying, particularly when viewing content with subtitles. Can anyone shed some light on what is wrong or how to correct this :confused:
  2. NX3
    NX3
    Dec 4, 2002
    3,493
    103
    +8
    Are you sure its not just normal overscan ?
  3. Caimbeul
    Caimbeul
    Jun 7, 2005
    734
    Kent
    +25
    if it is then its by a huge amount. I thought overscan was only at the left and right edges though?
  4. Caimbeul
    Caimbeul
    Jun 7, 2005
    734
    Kent
    +25
    Bump :)
  5. unique
    unique
    Aug 14, 2005
    9,381
    +1,211
    i had a problem playing mpg/avi etc in the correct ratio via hdmi. to play it correctly i use the scart output and stretch the picture via the tvs "cinema" mode (it stretches non anamorphic stuff to the right size). i think i might have had to set some stuff to 4:3 on the dvd player and use the tv to stretch it back the right way - sounds confusing, but just muck around with the different settings on both dvd and tv - you cant choose all the options with hdmi though
  6. David Mackenzie
    David Mackenzie
    Aug 28, 2003
    10,351
    Glasgow, UK
    +1,312
    No, overscan affects all sides.
  7. Caimbeul
    Caimbeul
    Jun 7, 2005
    734
    Kent
    +25
    Thanks for those replys. I am viewing via HDMI so may try it via scart for DivX.
  8. pierrev
    pierrev
    Jul 7, 2004
    I output via HDMI to a Panasonic AE500 projector - PQ is virtually the same across all modes of HDMI ( I think the PJ does the upscaling for itself) - the only difference is that if I output at the lowest mode (480p/576p) then I can still control the screen resolution from the PJ - in all other modes the aspect ratio on the PJ is locked at 16:9
    I only noticed this after I put the multi region hack in - but it may have been there already
  9. Caimbeul
    Caimbeul
    Jun 7, 2005
    734
    Kent
    +25
    I can set the Zoom features etc. You recon if I set it to 4:3 the the top and bottom overscan may lessen?
  10. unique
    unique
    Aug 14, 2005
    9,381
    +1,211
    you mean u CANT set the zoom feature when playing divx or mpeg? it doesnt work for me. i use scart (component will also probably work) and use the tv zoom setting to stretch the picture to the correct ratio (no over obvious overscan). i think with a couple of things i might have had to set to 4:3 on the dvd player first
    if u muck about with the settings you will get it without too much overscan or zoom
