Divx Playback Problems On Kiss Dp-1000
Discussion in 'Blu-ray & DVD Players & Recorders' started by makrenatt, Apr 2, 2005.
  1. makrenatt
    makrenatt
    Hi everyone, welcome to me first post.
    I bought a KISS DP-1000 a few months back and all seemed well.
    Now though if I put in a DIVX DVD with multiple episodes on it will freeze at 3.35 mins and need power cycling.
    If you skip past the offending time zone it will play fine.
    I have used many different makes of dvd, and ones recorded on other writers than my own but to no avail. :rolleyes:
    Can anyone help, if this is a firmware glitch then fine I will just have to wait for a new version. But if it is a hardware problem then it can go back.
    My DP-1000 has the toshiba drive, and has been been updated to the latest version of firmware so I could make it multi region.
    Hope one of you AV brains know what going on. :smashin:
  2. KraGorn
    KraGorn
    Aug 30, 2003
    4,740
    68
    Warrington
    +27
    Can't help with any useful info, I have a 450 but rarely play DivX files, but maybe it'd be useful to post this also on KiSS Forums in case it's a known problem.
  3. makrenatt
    makrenatt
    cheers mate, will do.
    I will report back when I have some usefull info. :D
  4. makrenatt
    makrenatt
    Looks like there is a piece of hybrid firmware that should fix problem.
    I will try it out and let you know. :smashin:
  5. poggs
    poggs
    Jul 21, 2004
    612
    28
    +26
    its a well documented firmware fault. get the latest hacked one as it cures it
