divx & pioneer 575
Discussion in 'Blu-ray & DVD Players & Recorders' started by Paulbmw, Mar 10, 2005.
  1. Paulbmw
    Paulbmw
    i have a few xvid films.some judder when played(as if the frame rate is low)some dont.I have checked the xvid frame rates of the films and they r the same.Can any one recomend possible cures.My tv is a toshiba 36zp46 connected using component leads.I have considered that it may be a burning/connection/player/encoding problem but there are so many possibilities :confused: a pointer as to where to look would be very grateful :smashin:
  2. NX3
    NX3
    Dec 4, 2002
    3,488
    103
    +332
    They will be packed bitsteam Xvids. Get Mpeg4modifier and unpackthem, its very quick and solves the problem. If you search on this forum you will find this mentioned many many times. Google for Mpeg4modifier, you'll find it.
