DivX on 100Hz TV
Discussion in 'Desktop & Laptop Computers Forum' started by chrbjo, Apr 10, 2002.
  1. chrbjo
    chrbjo
    Is it possible to adjust the refresh rate when watching DivX films or would it make any difference? Watched a film yesterday and sometimes the picture on the TV was really bad. Not on the monitor though. The picture looked like it was made of 5 cm high blocks not in sync with eachother. I guess it has to do with the 100Hz TV, but is there a way of eliminating or at least minimizing this problem? My TV is a Sony KV32-FX65 by the way.
  2. Desmo
    Desmo
    Jan 4, 2001
    14,454
    Braintree, Essex.
    +6,501
    Probably not a lot you can do about it. At what bitrate was the film encoded? This will obviously make a big difference to the quality on a large screen.
    When viewing a Divx you can't compare the picture quality of a monitor and TV.
    My encoded Divx's look almost identical to a DVD but are very large files and look fine on TV.
  3. chrbjo
    chrbjo
    24bit and 105.679 kb/sec.
    Noticed that the errors do occur on my monitor as well. More noticeable on a big telly obviously. Messed around with the settings in TVtool and got it slightly better.
    Thanks.
