Divx AND Xvid player
Discussion in 'Blu-ray & DVD Players & Recorders' started by Welshman, Jul 14, 2004.
  1. Welshman
    Welshman
    Can anyone rcommend a DVD player that plays Divx and Xvid from DVD-Rs and has a Pal prog scan. I understand that Kiss do one under £100 with good pic quality.
  2. NX3
    NX3
    Dec 4, 2002
    3,492
    103
    +8
    Pioneer DV-470
    Pioneer DV-575
  3. Hi-Jack
    Hi-Jack
    Pioneer DV-575 is not an option if you ever need subtitles.
    Pioneer stated officially to us it will not support these products with updates.
    KiSS indeed has some nice players and the quality they produce is the best
    but unfortunately they are also quit unstable at the moment and lack support for Qpel
    and GMC.
    never the less, KiSS is the only company releasing regular updates and the one coming in August 2004 will greatly improve the whole range.
    My advice, wait a couple more months and waut for second generation players.
    (DP-600)
    regards
  4. leeb
    leeb
    Jan 10, 2003
    880
    28
    Melton Mowbray
    +52
    Toshiba SD340e. Available multiregion from Amazon (79.99). Very happy with mine! :thumbsup:
  5. sapper44
    sapper44
    Feb 12, 2004
    551
    uk
    +64
    I have a Tangent 400 plays all flavours of disc.It supposed to play mixed formats on a single dvd which is pritty good.I have had a few problems with freezing with xvid so I rencoded using dr-divx and they play fine.I would advise a visit to www.vcdhelp.com or probabley better is the forums over www.divx.com
  6. dean randle
    dean randle
    Jan 9, 2003
    156
    UK (Bromley)
    +6
    Hi Sapper44,
    Have you tried the vga on the Tangent 400? I have a projector and wondered what it would be like connected as an altenative to using a laptop. Any feedback would be greatly appreciated.
    Thanks,
    Dean.
  7. sapper44
    sapper44
    Feb 12, 2004
    551
    uk
    +64
    Hi Dean Randal.
    Yes have tried it on a pj got something like 475vga it said as appossed to the normal progresive 525 etc.Pic was ok but not as good as component.Havent tried on pc monitor.Tried playing Xvid and divx played ok through pj and 5.1 discs played ok through my surround amp with coaxel connection.Have moved the player under tv as I felt this is a better option as I prefer to use the Samsung dvi player as I only play dvd and I plan to do a bit of gaming when I get my X box sorted.
