diva88 - possible picture problem, advice please.
Discussion in 'Arcam Owners' Forum' started by silverx, Jun 5, 2004.
Tags:
  1. silverx
    silverx
    Sep 22, 2003
    36
    I have a diva88 (not progressive) playing into a Panasonic PW6 via component. I have a problem playing most region 1 discs - There is a dark, reddish, band across the top of the picture when viewing 16:9 films/tv on a lot of discs - but not all. It is only noticable when the picture is quite dark but can be irritating.
    Has anyone heard of, or seen this problem before? If so is there a fix? I'd be grateful for any advice. :confused:
  2. Cameron
    Cameron
    you could try looking at your setup options for the dv88 and see if its set for PAL, NTSC or AUTO.
    CaM
  3. silverx
    silverx
    Sep 22, 2003
    36
    thanks for idea but unfortunately still does it on auto and ntsc :(
  4. Cameron
    Cameron
    hm, are you sure its not the tv's settings? I know on my projector that for region 1 dvd's I have to set it to sync with the new region.
    CaM
