DIVA T81 remote codes and DigiFusion FRTV 150 PVR
Discussion in 'Hi-Fi Stereo Systems & Separates' started by steeled, Mar 9, 2005.
Tags:
  1. steeled
    steeled
    Apr 23, 2002
    499
    28
    Maidenhead
    +54
    Hi All
    Just to let you know that if you are thinking of buying the DigiFusion FRTV150 Freeview PVR that it's remote codes clash with the DT81 DAB Tuner.
    If you change the Display on the tuner or try and change channel the PVR will also change channel.
    Just thought I would let you know before you go to Argos
  2. steeled
    steeled
    Apr 23, 2002
    499
    28
    Maidenhead
    +54
    Hi All
    Just to make life more fun I have now discovered that the DigiFusion also clashes with the remote codes the FMJ DV27 uses. For example the "Ok" button tunes to BBC 3 and mutes it. The reverse button brings up the EPG.
    Look like I will have to get rid of the DigiFusion box.
    HTH
