div-x
Discussion in 'Blu-ray & DVD Players & Recorders' started by john R1, Mar 13, 2005.
  1. john R1
    john R1
    Nov 2, 2002
    692
    16
    essex
    can someone tell me what div-x is keep hearing it talked about on various forums but dont know what it is ?
  2. cwick
    cwick
    Feb 4, 2002
    2,231
    Reading
    +95
  3. KraGorn
    KraGorn
    Aug 30, 2003
    4,745
    68
    Warrington
    +27
    It's a method of video encoding which achieves higher quality and smaller size than MPEG-2 used on DVDs. There's a long history to it which I won't bore you with :), which also involves another codec called XviD (read it backwards ;) ).
    It was used a lot to pirate DVDs in the days before DVD burners were around, hard disks were smaller and a DVD had to be ripped to 1 or more CDs.
    Nowadays it's typically used to VHS tapes and home movies recorded on a DVR (to make them smaller than with MPEG-2), as well as continuing to be used by some for DVD ripping but in these days of 250Gb+ hard disks space saving isn't the issue it once was.
