Ditigal camera
Discussion in 'Photography Forums' started by MartinImber, Apr 25, 2003.
  1. MartinImber
    MartinImber
    Apr 5, 2001
    3,851
    71
    Worcester
    +21
    My wife wants to buy a digital cameral she is currently using a Cannon camera which is about 3 years old, she would like a digital camera she likes Cannon, can anyone recommend any good ones:eek
  2. nathan_silly
    nathan_silly
    Brother has a Fuji S304, very good detail & resoultion. Comes supplied with a sun blocker- lens thingy. 6X optical zoom. About £300. Uses XD memory.
  3. MartinImber
    MartinImber
    Apr 5, 2001
    3,851
    71
    Worcester
    +21
    Thanks for your advice
  4. minimad
    minimad
    Martin
    I got to have a quick play with the new Canon Powershot A70 last weekend, felt nice, quite small, image resolution pretty good. You can get it for around £270.
    Alternatively look at the S45 or G3 (I think!) again, both Canon.
    Collin
  5. MartinImber
    MartinImber
    Apr 5, 2001
    3,851
    71
    Worcester
    +21
    Arghhhhhhhhhh!!!!!!!!!!!!!
    My wife has found my login!!!!!!!!!!!
  6. nunew33
    nunew33
    Jun 5, 2002
    1,735
    41
    Lytham St Annes, where people are put out to grass
    Martin, depends how much you want to spend and what you want.
    Canons A series are very good as are the S series or the more expensive but flexible G series.
    If its point and shoot you want the A range would be good.
    If size is an issue then the ixus range.
    If creativity is important then the S range
    If money is no object then the EOS D10 SLR:D
    A good website for seeing exactly what you get with canons (including menu options) is http://web.canon.jp/Imaging/BeBit-e.html
    Once you get your selected camera look on pricerunner for cheapest dealer then get jessops to price match if you want a local dealer
  7. shoehorn
    shoehorn
    I've got a Canon S45 - excellent camera - it has point and press for SWMBO and full manual control if I fancy playing with it......
    It's size is pretty good too.....
    Take a look at this site for in-depth reviews......
    http://www.dpreview.com/
  8. mij
    mij
    Jan 14, 2002
    3,458
    London
    +631
    In my opinion most of the known brands are good if you get at least a 2 megapixel with an optical zoom.
    One thing you should check is what kind of battery comes with the camera, some digital cameras kill the batterys very fast,
    I find Sony's infolithium battery is very good and gives a readout of remaining time.
    mij
