berkeley384
- Joined
- Nov 28, 2006
- Messages
- 1,549
- Reaction score
- 307
- Points
- 425
Hi there all
A few years ago Home Cinema Engineering owner (Piers) came to my home and set up a Feedback destroyer to eliminate some excessive boom and help create a more even sound across my primary listening area.
This was set up using my old Denon 3806 with Audyssesy switched off - several adjustments were made and Audyssey was run afterwards.
Move on 5 years and Im now setting up my Onkyo 818 - Ive run the Audyssey XT32 set up wizard - measured in 8 places, and had a listen and i can tell its a tad more boomy at the left side of the room closest to the sub than it is at the right.
My question to you is - do I keep the FD or ditch it. since a nice man with more expensive kit than I have set it up and nothing has changed since in terms of speaker Make / Model / placement etc will having the FD in line have any negative effect, am I limiting / throttling anything by having it in line. Am i limiting the quality of the sub frequencies by having this device in line?
Steve
Steve
