Distribution Block
Discussion in 'Cables & Switches' started by riverrun, Aug 18, 2004.
  1. riverrun
    riverrun
    Jul 4, 2004
    37
    I've made a distribution block with 4 x MK twin sockets and LoRad. It's a bit late to wonder now, but was making the enclosure out of wood a very bad idea?
  2. eviljohn2
    eviljohn2
    Jul 8, 2002
    7,529
    Near London.
    +208
    I can't think of any reason why it would be a problem. Wood's a rubbish conductor and if you're competent enough to try such a project then I'm sure it's wired correctly. What is that you're concerned about?
    I'd like to see a picture though :)
  3. cwoj
    cwoj
    nope, sounds ok to me
  4. hornydragon
    hornydragon
    Dec 19, 2001
    28,299
    +1,215
    a couple of other people did this a while ago but used plastic casing i think
  5. pemberto
    pemberto
    Oct 14, 2003
    500
    28
    Huntingdon
    +32
    I was one of those people who made my own distribution block based on StooMonster's design. If you search on either StooMonster's or my own username you should find all the details and comments raised.
  6. riverrun
    riverrun
    Jul 4, 2004
    37
    I suppose conventional distribution blocks made of metal, ABS, or plastic would break if you kicked them about a bit, just like a wooden one, but I was mainly worried about fire, and the circumstances that might cause ignition from within the box. Enclose pic for eviljohn.
  7. eviljohn2
    eviljohn2
    Jul 8, 2002
    7,529
    Near London.
    +208
    That looks great :eek:
    The only way you'd get ignition is if the wires were to spark. No chance of that if it's wired correctly. I suppose you could earth the metal screws that hold it all together as well. ;)
  8. GrahamC
    GrahamC
    Jul 22, 2001
    2,258
    Morecambe, U.K.
    +67
    I did something similar for my computer station but with 4 twin sockets, no probs for about 4 years. :thumbsup:
