distributing sky digital
Discussion in 'Sky Digital TV Forum' started by Dominic, Sep 26, 2003.
  1. Dominic
    Dominic
    Mar 2, 2001
    288
    Essex
    +6
    i have a std grundig box and want to send sky to multiple rooms. I have a TV and seperate FM areial in the loft and this is multiplexed via a single downlead to my living room. What i want is to send the RF2 output to the loft then send it down to kitchen, bebrooms and office. etc .
    question
    If i plug my aerial (from wall plate ) into the sky box, then RF2 output out of the living room up the wall into the loft and into the input of a distribution amp and then using the outputs of that to send sky and terstrial down a single coax to each room.
    What i also want is to use the magic eye's in each room to be able to change the sky channel in the living room. Can i use a std booster / distribution amp, like the one in argos cat page 713, labgear 4 way £17.25, ive heard some dont pass the IR signals from the magic eyes is this right ?
    if thats true is there anyone that can suggest a suitable solution ?
    Dom
  2. owenw
    owenw
    Jul 19, 2003
    269
    Ireland
    I got one of the 4-way Global TV Link amps which you can see here:
    http://www.stuff4tv.co.uk/Sky Other Accessories.htm
    Unlike the SLX amps it can be used with more than 1 "magic eye"
    I got caught out with the SLX amps as they can only pass the remote signal to one additional TV but the image signal to multiple TV's
    Also, any of the magic eyes for sky digital should work with it regardless of brand.
    hth,
    Owen
  3. Dominic
    Dominic
    Mar 2, 2001
    288
    Essex
    +6
    owen,
    thanks for the promtp reply, looks like i will be going down the same road as you. However, the company that make the magic eye ( global coms) is a 5min drive from me, i think i will call them to see if they sell to jo public, could save some cash if i can cut out the middle man.
    thanks for the prompt reply.
    Dom
  4. owenw
    owenw
    Jul 19, 2003
    269
    Ireland
    No probs.
    Yeah it's definately worth giving them a bell you'll probably get it half price or near enough :)
  5. adeyb
    adeyb
    Jul 28, 2003
    239
    Cheshire
    +10
    "Unlike the SLX amps it can be used with more than 1 "magic eye"
    I have a 4 way slx amp from maplins (25 quid) and have an eye in the kitchen and bedroom, works sweeeet
    ta
    adeyb
  6. hornydragon
    hornydragon
    Dec 19, 2001
    28,299
    +1,215
    Channel plus do exactly what you need mate and you can feed VHS DVD and another source as well look at the 5558 system and it is available with Nicam encoder tooo
  7. Dominic
    Dominic
    Mar 2, 2001
    288
    Essex
    +6
    thanks for all the info, how much is this channel plus kit, any chance of a link
    adeyb
    seems reasonable joby from maplins for 25 quid ill take a closer look
  8. adeyb
    adeyb
    Jul 28, 2003
    239
    Cheshire
    +10
    link for you to maplin aerial amps (slx)
  9. adeyb
    adeyb
    Jul 28, 2003
    239
    Cheshire
    +10
  10. hornydragon
    hornydragon
    Dec 19, 2001
    28,299
    +1,215
