Distortion on Right Channel of Cambridge Audio A500. Help?
Discussion in 'AV Receivers & Amplifiers' started by Manzmann, Jun 24, 2005.
  1. Manzmann
    Manzmann
    Hi, I've had my cambridge audio a500 for about two years. recently, the left hand channel stopped working. After a couple of weeks of playing music through the right channel it began to distort quite badly. a few days after this the left channel began to work again with no distortion, so now I have both channels working again but the right channel is horrbly distorted.
    Its not the speakers as I've changed them over and tried others.
    Any help would be great.
  2. bob1
    bob1
    Nov 7, 2002
    4,458
    Sheffield
    +131
    I had the same problem some years ago with an amp ,i had to change the pre driver and the main output,it work fine after that.
    I'm not too shure about the channels not working a then being ok.
    I would get it to a repairer for fixing.
