Distorted image on Loewe Aconda...
Discussion in 'General TV Discussions Forum' started by ddias, Mar 24, 2002.
  1. ddias
    ddias
    I just picked up a 2nd hand 32" Loewe Aconda and there is a noticeable curving of the image both horizontally and vertically in the top left hand corner of the screen.
    Any ideas why this might be, other than a faulty set? And how do I fix it? I have a pair of Mission 780 speakers on either side of the set, but they're about 1m away on either side so I doubt it will be these (they never effected my previous TV.)
    Thanks in advance
    ddias
  2. Garrett
    Garrett
    Apr 21, 2001
    43,268
    2
    167
    The best thief you'll never see.
    +8,182
    I have a slight bow at the sides of my picture on my Loewe in pan mode but have been told by a number of people that this has nothing to do with the magnets, the fault they can cause is a colour stain in the corners of the screen. I think this fault show’s up on flat W/S TV more than a normal4:3 (even though I have spotted it on them sometimes).
    If you put in a search on Loewe there is some discussions on geometry, also how to get into the service menu and what to alter, that may help you.
  3. Garrett
    Garrett
    Apr 21, 2001
    43,268
    2
    167
    +8,182
