Distance of unshielded speakers to TV?
Discussion in 'Home Cinema Speakers' started by MysteryMan, Feb 26, 2003.
  1. MysteryMan
    MysteryMan
    Nov 18, 2002
    633
    Cheshire
    +32
    A number of the speakers I am looking at are unshielded and I wondered if there is a guidance for how far away from the TV they need to be to avoid problems.
  2. Nobber22
    Nobber22
    Jun 6, 2002
    2,978
    Berkshire
    +110
    Depends on the speaker and the telly, but think at least 30cm away.
  3. chez
    chez
    Feb 25, 2003
    1,549
    41
    Dallas, TX
    +19
    With my Ruark Prelude IIs, it's more like at least 30 inches!!!
    As for subwoofers, unless they're shielded they need to be a good distance away. My M&K sub really screws with my TV unless it's at least 4 feet away!!!
  4. Apocalypse
    Apocalypse
    Aug 14, 2002
    840
    19
    Sheffield
    If you own a rear pro TV you can be sneaky. The electronics affected by speakers are situated at the bottom of the TV so you can place speakers right next to the screen as long as the drivers are high enough (ie magnetic field can't reach the electronics). I successfully used my floorstanders right next to my rear pro TV for years like this.
    Phil
  5. sticker
    sticker
    Jan 14, 2003
    1,152
    36
    Sydney, Australia
    I would endorse the 30 inches guidance, my old Eltax LR6.5 left a permanant green stain on both sides of my TV picture, I had mine at 30CM:(
  6. Reiner
    Reiner
    Jul 16, 2000
    3,315
    61
    Germany
    +13
    1m (3 foot) is a safe bet. Though it depends on the speaker and how sensitive your TV is.
  7. Seychelles Sam
    Seychelles Sam
    Dec 29, 2013
    4
    4
    Coventry, United Kingdom
    Sorry to reopen this but is this still an issue with anything other than CRT models?
  8. PSM1
    PSM1
    Dec 20, 2008
    26,007
    +5,280
    only an issue with CRT TVs. if you have and LCD/Plasma etc. then there is no issue with unshielded speakers.
  9. BlueWizard
    BlueWizard
    Jun 19, 2007
    20,790
    +3,791
    As PSM1 points out, magnetic fields only effect the older large tube TVs. The electron beam in the TV-tube was aimed by magnetic fields; four plates for horizontal and vertical aiming. If a magnet was near by, the aim would be off. But modern flat screen are long past that method of producing a picture. I'm not aware of any problems with LCD or Plasma TVs and magnetic fields.
    I will say that I had a CRT TV and some large 12" speaker that were about 12" away, down and to the side, and didn't have any problems. Though with the same equipment, but a slightly different configuration, I did have some discoloration of the screen near the speaker. I simply shifted the speaker a bit and the problem went away. But again, that was CRT/Tube type TV. This is not a problem with modern TVs and Monitors.
    Steve/bluewizard
