Distance of cable between Sky dish & box
Discussion in 'Sky Digital TV Forum' started by Darth Vader, Feb 13, 2002.
  1. Darth Vader
    Darth Vader
    Feb 13, 2002
    102
    16
    Middlesex
    Can any of you Jedi's help ?.
    How long can the cable run be between the dish and the Sky digibox. The Landlord of the property I live in won't allow me to install a dish on the house. But they will let me put one on the garage which is quite a distance from the house. I have repeatedly emailed Sky this question but have received no reply.
    May the force be with you.
  2. Starburst
    Starburst
    Jul 13, 2000
    17,846
    Ilkeston
    +975
    I think the maximum length is around 40 meters.
    For longer lengths a signal amplifier is needed along with the use of good quality CT100 cable.
    Good source of info.....
    www.satcure.co.uk
  3. Frank2
    Frank2
    Dec 20, 2001
    14
    UK
    You never receive an answer from Sky!
    I am living in a grade 1 listed house and had a similar problem (You are not allowed to put a dish on one of these houses). I bought a reel of 100M CT100.
    A 100M run was too close to the limit. Now I moved the dish closer (15M). The dish is 1Ft of the ground. This qorks great, but I have to keep mowing the grass in the summer!
    I am sure 40M will work.
  4. Darth Vader
    Darth Vader
    Feb 13, 2002
    102
    16
    Middlesex
    To Frank2 & Starbust
    Thanks for the info it's been a great help!. My Deathstar will now be complete!
    From The Dark Lord of the Sith
