C
CZOLG
Hello,
I've been reading all the posts regarding aerials for the past two days now.
I do need to ask a question. I live in the UB8 2HL location, it is a bout 30 km from Crystal Palace. Is this considered far or close to the transmitter?
I am looking for some sort of compact external aerial ( I tried indoor one but it hardly picks up analog, nevermind freeview, even with booster).
Since this is a rented room I cannot put the aerial on the top. The only solution for me is to put one on the top of the garage which is significantly lower than rooftop. The garage is between two houses, so probably not a best place.
I am looking for a general advice. Will this work? What aerial should I use?
I get no reception from the inside of the garage with indoor aerial, so putting one on the rooftop would make a difference?
ANy help greatly appreciated,
