Distance for rear speakers?
Discussion in 'Home Cinema Speakers' started by yeff, Oct 19, 2005.
  1. yeff
    yeff
    Oct 25, 2004
    54
    Hi, I am just about to get room sorted for new set-up, and was wanting to know if putting my rear speakers 25ft apart would be ok?
    They would be equal distance from where I will be sitting, also would I be better going with a 6.1 or 7.1 if the distance for rears is ok?
    Room is 25x12, and my seating position is in middle of room,with chair just off back wall, speakers are Canton CD50's.
    Thanks Steve
  2. thekingbeyond
    thekingbeyond
    May 24, 2004
    6,319
    oxfordshire
    +411
    I would go for a 7.1 set up, 25ft is a big gap for 2 speakers to fill and i think adding a pair of bipole or dipole speakers would improve the surround effects and fill in any acoustic gaps
  3. Slimchandi
    Slimchandi
    Dec 23, 2004
    486
    +3
    I take it you mean to put the Cantons in the corners of the room?
    You'll get a much better soundstage using 7.1, with the surrounds to the left and right and rears on the wall behind you, but not 25ft apart!
  4. yeff
    yeff
    Oct 25, 2004
    54
    So what would the best distance from seating position be for the surround speakers? Also would a couple of CD10's be of for the rears?
  5. thekingbeyond
    thekingbeyond
    May 24, 2004
    6,319
    oxfordshire
    +411
    how wide appart are your left/ right fronts
  6. yeff
    yeff
    Oct 25, 2004
    54
    They will be about 5 ft away from screen on each side, so approx 4ft from side walls.
