dissapointing qed q-sync
Discussion in 'Plasma TVs Forum' started by spinner, Oct 11, 2004.
  1. spinner
    spinner
    Aug 8, 2004
    202
    newcastle
    +5
    currently using panasonic w5 and had been thinking about the q sync rgb/svga converter since last xmas
    so this weekend i bought the qed q sync box,and i have to say its not worth the money,picture was no better if not slightly worse than s video,picture had more noise on as well
    one thing i noticed on the w5 was that on the "PC" mode (which the plasma must be on to watch via svga ) the colour adjustment option had dissapeared all the colours were far to strong with now no way to turn down,and the "extended black drive" option was also missing from the menu
    one school of thought behind the sometimes poor quality of rgb/svga is that any picture signal converted to another (rgb-svga) will always loose some quality.
    does anyone think the JS box would be any better?
  2. nobbydog
    nobbydog
    Jun 19, 2003
    262
    Comfy basket in the utility room
    Yep! I tried the Qsync and the keene Syncblaster, both were very disappointing for me also on my PW6. Went to a JS box RGB/VGA and the difference is clear. If anything the colours are too strong at first and it takes a bit of fiddling to tone them down. Also worth mentioning the massive improvement of the JS box over the scart input. Money very well spent IMHO :lesson: .
  3. spinner
    spinner
    Aug 8, 2004
    202
    newcastle
    +5
    yes the colours were strong.....how come the pany looses the colour adjustment settings and real black drives in pc (svga) mode????
