DisplayPort
Mr Snrub
I've got a new laptop with a DisplayPort output, but although I've read a few articles online about this output, I'm still a bit confused.
As preset, I connect my laptop to my LCD TV via VGA cable to watch films, can I achieve this using the DisplayPort output instead? And if so, will it achieve a higher definition than VGA if I use a DisplayPort to HDMI cable? (at present I can only display at VGA 1024x768)
Mr_Ceee
Assuming your laptops port is Dual mode you can use Hdmi with the correct adaptors. The resolution though is probably a limitation of your TV. You need to check the manual to see what resolutions it will support.
