Question DisplayPort to HDMI 2.0a
Discussion in 'Cables & Switches' started by tomu94, Aug 13, 2017.
  1. tomu94
    tomu94
    Aug 13, 2017
    4
    UK
    I'm new here and although I've done quite a bit of research I'm fairly inexperienced with 4K, chroma, colour depth etc. so go easy on me!
    I have the Samsung UE49KU6400U which I'm very happy with but I'm having trouble getting HDR to work with my PC. It's through my own fault really as I purchased a gtx460 graphics card for my pc to get 4k to the TV but I missed that HDR will only work from the DisplayPort on the graphics card and the TV does not have a DisplayPort.
    So I looked into converting the DisplayPort (which does support 1.4) to HDMI 2.0a (which the TV supposedly supports through a firmware update last year). From what I Understand, it has to be 2.0a in order to send HDR?
    I have looked everywhere for a DisplayPort to HDMI 2.0a converter that is sold in the UK and cannot find one anywhere. I have found only one that is sold in America on Amazon but does not ship to the UK. www.amazon.com/DisplayPort-HDMI-2-0a-Active-Adapter/dp/B01B6ZOMIS (this product was sold on the UK amazon site but now shows as unavailable and unknown wether it will be back in stock)
    If I do manage to find this converter in the UK, will HDR work or am I wasting my time?
    I cannot afford to buy another graphics card so my only solution is this converter I think...
    Thanks In advance :)
  2. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    28,383
    The Borders
    +3,433
    'From what I Understand, it has to be 2.0a in order to send HDR?' - your devices all need to be HDR_ compliant - ignore Version Numbers and look for Feature support.
    I don't see HDR mentioned on the Adapter you link to - I'd contact the Manufacturer to confirm what it supports.
    Joe
    PS Uptab seem to ship to the UK!
