Hi there,
I have a Panasonic TH-42PWD5BX connected via component to my Denon AVC-A1SE.
Connected to the AVC-A1SE I have a Denon DVD-2900 (component) and a Sky+ Digibox via the JS RGB->Component converter.
So far...so good...
But...there's always a but...is there a way for the PW5 plasma to identify just what video signal it is being fed with?
Progressive, PAL/NTSC etc?
I did see some time ago a way to go into the service menu for the tuner box (which I don't have) so it would display the type of video signal but is this possible on the PW5 plasma itself without the tuner/media box?
I would also like to get some idea of the run hours on the display itself - can this be done?
Thanks & regards,
-=Glyn=-
So far...so good...
Thanks & regards,
-=Glyn=-
