display
Discussion in 'AV Receivers & Amplifiers' started by damien, Jan 22, 2003.
  1. damien
    damien
    hi guys i have a problem i recentley bought a sherwood rd 6103 av amp from richer sounds £119.00 smart price i think and i have it hooked up to a sony dvpns700 dvd player is there any way of displaying what source the amp is using .....eg DVD X BOX all i usually have is cd o1 then a small dd dts text in the corner thanks lads
  2. Jase
    Jase
    Mar 16, 2001
    9,410
    South Coast
    +857
    The display will vary from amp to amp. My Denon has a small light that indicates which input you are using (dvd, cd etc). The display will show what mode the amp is in, Dolby Digital, DTS etc. Also got several other lights that indicate whether surround back speakers are switched on, amp is auto mode etc etc.
