T
TomT
Hello.
I wasn't sure which forum to post this to, since the problem involves a number of components.
Recently I have noticed a semi-transparent horizontal line scrolling from the bottom of my display to the top, then repeating. It's very light, and does not show up against dark backgrounds.
Here are the components involved and set up: Arcam DV27 DVD player connected to Pioneer VSX-49TX receiver via progressive component from the Arcam, and also non-progressive connection, (both to the Pioneer).
I use the Pioneer for video switching, and it is connected via component to a Sanyo PLV60HT projector.
The reason I have two connections from the Arcam is some of my DVD's are PAL, and my model DVD player does not support PAL progressive, so in order to get the DVD to frame properly, I used the non-progressive output from the Pioneer.
The Arcam is set to Auto for both region and video (switches between NTSC and PAL), the Sanyo is also set to auto.
For quite some time this set up has worked perfectly, but as mentioned above, I am now getting this scrolling horizontal line (sometimes more than 1), which is very distracting.
One thing I have noticed is that when playing PAL DVD's, either via the progressive or non-progressive output from the Pioneer, the line(s) are not present.
I'm not sure about the best way to troubleshoot this, since I don't have another display device to test on (i.e. no PAL TV). I am hoping that someone might be able to diagnose the problem from the symptoms.
With my limited knowledge, I am not sure if the problem is in the DVD player, video switching by the Pioneer, or, the projector.
Any help would be greatly appreciated.
Thanks in advance....
Tom
Tom
