display drivers occasionally stop working
Discussion in 'Computer Components' started by santosh123, Jan 5, 2012.
  1. santosh123
    santosh123
    Aug 7, 2011
    64
    i have a 560 ti, and occasionally my screen goes black for abouts 6 seconds and turns back on woth a notification telling me the drivers stopped working. the drivers for the card are up to date. do you have any idea on whats going on
  2. SUMMONER
    SUMMONER
    Apr 4, 2009
    1,399
    London
    +251
    I have had this on a customer's PC once and it turned out to be caused by a weak/dodgy power supply.
    If you haven't checked the temperature of the video card, that is also something worth looking at.
  3. santosh123
    santosh123
    Aug 7, 2011
    64
    I have a 750w OCZ, should be enough right? And yeah I've checked, I'm
    Hitting 45 Ish during gaming, and in the 30's/20's at idle
  4. SUMMONER
    SUMMONER
    Apr 4, 2009
    1,399
    London
    +251
    OCZ psus are in general rock solid, been using their budget StealthXStream 1 & 2 series for a long time in my/customer PCs.
    Consider what is easier for you as a next step, swap the PSU with a friend for a week or re-install Windows?
  5. WonkyEwok
    WonkyEwok
    Dec 12, 2004
    585
    43
    +108
    I used to get that with a gtx580, win7 64 bit, but I think that one of the recent nvidia driver updates has fixed it for me (within the last 1-2 months). 290.53 beta is available now. As it's beta the nvidia control panel doesn't tell you about it automatically though I think.
