display advice
Discussion in 'Plasma TVs Forum' started by DEANO65, Jun 22, 2003.
  1. DEANO65
    DEANO65
    Feb 19, 2003
    45
    leeds
    ive got a fujisu 50 connected to it is a sky digital box,by scart(ixos)rgb enabled at both ends picture is good but i can see horizontal lines across the screen especially with bright reds,can any one help thanks
  2. briandzo
    briandzo
    Dec 12, 2002
    373
    19
    Newbury , Berkshire
  3. DEANO65
    DEANO65
    Feb 19, 2003
    45
    leeds
    cheers it def is what you said, ill look into fixing it, can you tell me ,the js lead you use is it for sky to component and is it better than scart to scart rgb enabled cheers im thinking about getting one thanks for youre time deano
  4. briandzo
    briandzo
    Dec 12, 2002
    373
    19
    Newbury , Berkshire
    for thoughts on YUV or RGB..... read another post i started.
    search for 'RGB or Component - Preferences'
    my js box converts scart to component.
    My system is setup for YUV as my dvd player had YUV outputs.
    it's seemed easier to take one route and stick with it throughout system
    I also knew that the iscan ultra couldnt take RGB as an i/p.
    it had to be YUV.
