Quantcast
Disney+ Information
BigTelHols
Started to watch the Xmen cartoon yesterday, brought back memories and the Simpsons movie last night. Haven't got Atmos so can't comment on that and haven't watched any 4K yet...
gunner84
Is it possible a mod can move this thread to the TV/Movie on demand streaming forum, not sure why we have this thread and another in the movies/TV streaming forum, I like to check both and its anoying having to go back and forth?
Perhaps then lock the other Disney launch thread?
BMox81
I’d keep this one here personally-the more sensible folk seem to visit this thread as opposed to the news threads in the streaming section....
Plus this one has been going longer...
gunner84
Yeah this one is a good thread, just seems pointless having 2 threads on the same subject in different sub forums.
Chinstroke
Question for those who signed up using topcashback. If it didn’t track what did you put in as order number when putting in claim. I’ve checked my account and my emails and there doesn’t seem to be one
Yes I watched the mandalorian yesterday one ep on the ATV 4K and another with the LG C9 app. Thought they were pretty similar in quality. Even with the reduced bit rates I thought the quality was pretty good although the audio dynamics was a little lacking and I had to boost the volume a little. Is this a Disney thing?
jwsg
Ive found the D+ audio to be the most noticeable issue but if they're using a 256K 5.1 stream instead of the 700+ some use for Atmos streams its not surprising - dynamic range and ambiance might be things compromised for low bit-rates.
For the NowTV app with boost in 5.1 over ARC I have to the have the receiver volume turned up - a problem when forgotten before changing back to TV etc.
MarkE19
I can move this thread if it is wanted by the thread starter and a few others that post here. But so far you seem to be the only one thinking it should be moved :)
So lets see what the masses want and I will decide what is best to be done.
Mark.
gunner84
Mark.
No worries, I just like to check both threads and find it a pain having to keep going back and forth between the sub-forums.
Graham
I thought the same, the picture was quite good but the sound seemed almost entirely lacking in dynamic range, with bass practically non existent (although this tends to be an issue with several Disney discs to be fair)
gunner84
I've only watched The Mandalorian so far, the sound is very poor and I have to boost the volume up a lot just to hear it clearly.
I hope this is not the case with all the content, perhaps it's the bandwidth throttling causing this?
I have not got Atmos but even still the sound quality is really poor.
jwsg
They're switched to a low bandwidth 5.1 audio option (maybe 256Kb/s) whereas streaming Atmos tracks are often 700K+. The extra benefit to the internet is tiny but it's making all the films sound like DVDs
novahob
I'm getting 5.1 show through my amplifier for between 1 to 3 seconds at the start then reverting stereo and not changing back to 5.1. Anyone else getting this behaviour? As I'm reading above some are getting 5.1. I know my amplifier is a few years old but plays Blu-ray's, prime video and Netflix fine. Any other suggestions of something I might need to change?
Nobbler
Mandalorian was bad until they added Atmos - now they’ve taken it away again it’s gone back to being poor.
Another point is the 4K HDR section has been removed from the Movies genre list when you select movies on the left panel. At the end was a 4K HDR section...
paulst10
Is there a way to remove something from your continue watching list? Only i started checking a few things using the developer tools on the Firestick and want to remove them..
gunner84
One way to do I would think is to play movie and fast forward to very end.
-gonzo-
As said by gunner above, If it’s a series then play the last episode and do the same.
BMox81
low-def.
It’s showing on my UK account via ATV
palace
Weird as i normally watch via nord vpn and find france good for servers so i usually stay logged intomthat.Yesterday i was adament i saw onward on my disney via firestick and even started watching the first 10minutes then turned it off.Now today it has gone so i do not know why i received it yesterday and not today.
tony428
Does anyone know why the second season of ‘Elena of Avalor’ isn’t showing on Disney Plus even though it’s listed on the advertised content? My daughter loved watching it on Disney Life but now can’t on Plus.
Trending threads
Latest News
MQA expands global partnerships for high end experience
  • By Andy Bassett
  • Published
Samsung 2020 TV app lineup upgraded
  • By Andy Bassett
  • Published
Film festivals move online: We Are One starts 29th May
  • By Andy Bassett
  • Published
Bafta 2020 TV Awards to proceed behind closed doors
  • By Andy Bassett
  • Published
Tidal brings Dolby Atmos Music to home cinema setups
  • By Andy Bassett
  • Published
