Dismantling an HD-6C Lens - how?
Discussion in 'Cable TV & Virgin Media TV' started by cosaw, Jun 27, 2005.
  1. cosaw
    cosaw
    Jun 14, 2003
    753
    Stockport, Manchester
    +20
    Hi all,
    Was wondering how easy the HD-6 lenses are to take apart to clean on the internal surfaces. Is it doable and if so is it advisable or will I have problems getting them back together again?
    Any advice welcome.
    Thanks,
    Simon
  2. Chris Frost
    Chris Frost
    Jul 14, 2000
    2,782
    Cheshire
    +109
    It's do-able, but why risk scratching the lenses or having focus problems after reassembly for the sake of a little dust? Are they really that bad?
    Regards
  3. cosaw
    cosaw
    Jun 14, 2003
    753
    +20
    Hi Chris - thanks for your reply,
    No I don't think they're that bad. Just wondered if it was easy or advisable in any circumstance. On your advice it seem not - and thats enough for me - I won't fix what aint broke but if it was simple and risk free I would have had a go. Suppose there is little way anything can get inside the lenses anyway.
    Many thanks for your advice,
    Simon
