Dismantling a 42wh36
Discussion in 'Cable TV & Virgin Media TV' started by maumau2000, May 21, 2004.
  1. maumau2000
    maumau2000
    Excuse my stupidity, but I cant quite figure out how to take apart the 42wh36 for the purposes of mechanical convergence. :confused:
    In Demon's post it seems that the 51wh36 front grill can just be pulled off. However on the 42 the two lower side mouldings appear to overlap the grill so it cant just pull off. It looks like the side mouldings have to come of first, but I dont see how...
    Any help would be appreciated.
    Cheers.
  2. Lizzard
    Lizzard
    I have the servicemanual for the 42/51/57 in paper format but i don't have a scanner.
    Anyway, there are on the 42" four screws that holds the panel you should remove first before snapping the panel off.
    The screws are positioned on the both sides of the TV at the back of the panel if you get me?
  3. maumau2000
    maumau2000
    Ah, got it.
    Didn't realise there are 2 grey panels at the back on either side that cover the 4 screws - have to remove these first.
    Thanks!
  4. HBK757
    HBK757
    Jan 15, 2002
    153
    16
    Doh, wrong thread.
