Disk utilisation chart?
Discussion in 'Computer Software & Operating Systems' started by Monty Burns, Jan 12, 2008.
  1. Monty Burns
    Monty Burns
    Jul 25, 2005
    3,869
    Londoner living in Bahrain
    +140
    Hi Guys
    anyone know an app/way of displaying disk space utilisation? I have recently setup a system with Vista 64 on a 24gig partition but, between it and a the couple of apps (nothing big!) all the space has gone....:confused:
    I'v done the usual stuff like clearing explorer, temp files, deleting page files etc.
  2. Monty Burns
    Monty Burns
    Jul 25, 2005
    3,869
    +140
    scratch that, got one :thumbsup:
    Now I have two large files, a hibernation and pagefile. Problem is, I have set the system to "no pagefile" but it won't remove it or delete it - keeps saying its locked. I managed to get rid of the hibernation file. I'm using Vista 64.
  3. Moosh
    Moosh
    Sep 12, 2004
    2,004
    2
    Bristol
    +469
    After you set your system to no pagefile, did you reboot straight away?
    Moosh
  4. Monty Burns
    Monty Burns
    Jul 25, 2005
    3,869
    +140
    Yeap - although I have solved it now.
    Basically, i reset the pagefile to 16meg, rebooted, then set it to zero again. All gone now all though I dont know why I had to do it a long way roung.
    Thanks anyway!
