Disk skipping on the Sony DVP-S735D
Discussion in 'Blu-ray & DVD Players & Recorders' started by owenmj, Sep 2, 2001.
  1. owenmj
    owenmj
    I've had a Sony DVP-S735D DVD player since about May and never had any problems with it. Recently however some disks (Yellow Submarine and The Mummy), sometimes pause and then skip back a track.
    Has anyone else had the same problem? Is it more likely to be a problem with the player or the disks?
    Don't know if this makes a difference but I had the machine chipped by the supplier when I bought it.
    All advice welcome!
    [email protected]
  2. johnson
    johnson
    May 12, 2001
    552
    Essex
    +6
    Sounds like dirty dicks to me.If they're clean,go into the sevice menu and do an auto calibrate on those disks.<br />By the way,exellent hatrick saturday!
  3. johnson
    johnson
    May 12, 2001
    552
    Essex
    +6
    I think my last post should have read "dirty disks"
  4. Guest
    Are you alright there mate?
  5. owenmj
    owenmj
    Thanks for the advice - looks like my personal hygene is causing the problem.
