disk mirroring
Discussion in 'Desktop & Laptop Computers Forum' started by mwltuk, Aug 7, 2004.
  1. mwltuk
    mwltuk
    Hi, anyone got suggestions for disk mirroring. I have XP Pro and two 80 Gb IDE drives. I want the second drive to be a copy of the first for resiliance purposes. A simple software solution would be best.
  2. RobsterD
    RobsterD
    Dec 11, 2000
    891
    Southampton
    +12
    I use Norton Ghost,clone mode will do what you require or you can backup the disc to an image file.
    Rob
  3. Loftus
    Loftus
    If you have WinXp you may want to consider the built-in software raid functionality (MS call them "dynamic disks"). Here's some reading....
    Windows software raid
  4. Ingo Bingo
    Ingo Bingo
    Jul 19, 2004
    829
    London, Middx
    +10
    True enough a mirror will work well, a striped volume will give you a quicker read, write response, but a mirror will back up your data more securely, make sure both disks have a bootable partition other wise its difficult to retrieve data if the first disk goes down.
    Alternatively use an older drive with a small partition as the c drive & mirror your data on the other two.
