Disk Eject 2-The Final Solution.
Discussion in 'Computer Components' started by evdama, Jan 10, 2012.
  1. evdama
    evdama
    Jul 11, 2008
    38
    Episode One is here
    http://www.avforums.com/forums/cd-dvd-blu-ray-drives-writing/1442373-disc-eject.html
    Well, zero response - err, thanks chaps.....
    But I found the solution!
    On Xmas eve my sons xbox started doing the same thing,only its owner was more stroppy.
    Googled the fix in seconds from the Xbox community -it's the tiny drive belt just inside the tray opening .
    It either gets grease on it or it just slackens with age -like a few other things....
    Ebayed a deal- Five new belts for £4.
    Maplin do them too (part no. FD36P) but at a considerably higher price if you have no local branch.
    Works a treat and other than the fascia plate theres no dismantling required.
    Best of all it also worked on the two computer DVD drives :thumbsup:
  2. fraggle
    fraggle
    Dec 11, 2002
    1,507
    Milton Keynes
    +57
    Excellent news.
    I wouldn't be too upset that you didn't get any responses the first time, someone has to be the first to link this fault in PC internal drives and the same problem in the XBox drive - well done :)
