Paulleahey
Does anyone know how to access the disk clean up utility from the new EPG? I've just spent about 10mins on hold waiting to speak to someone at Sky but to no avail...
It is. And it's now called Sky+ Rebuild.I believe it's now services, 0, 01 select on the new one.
A quick search and you would have found the info you wanted straight away!!Does anyone know how to access the disk clean up utility from the new EPG? I've just spent about 10mins on hold waiting to speak to someone at Sky but to no avail...
no it doesn`t, just make sure you select rebulild and not full system reset, if you do the reset you will loose everythingdoes this process delete all your recordings or is it like the disc defragmenter on a pc, where you dont loose any data?
