Dishes for SKY/+
Discussion in 'Sky Digital TV Forum' started by stanleyntl, Sep 9, 2005.
  1. stanleyntl
    stanleyntl
    Dec 6, 2003
    806
    28
    Worthing, Sussex
    +44
    What dish size is suitable to improve reception during bad weather?
    I get "no signal" during bad downpours.
    Upgrading to a SKY PLUS receiver - if I use twin coax, how does this affect dish size?
    Will quad LNBs fit most dishes?
  2. jackuzi
    jackuzi
    Dec 3, 2001
    253
    16
    South Wales
    Not a direct answer mate but we were losing signal during rain and I called Sky engineer in. He found that the dish wasn't aligned properly and he improved the signal quality from 25% to 70% on the Sky+ box and from 10% to 50% on the 2nd box.
    We no longer lose the picture during rain :thumbsup:
    Maybe you should try this first before looking to replace the dish.
  3. GGTVBD
    GGTVBD
    Feb 5, 2004
    3,365
    Bradford, West Yorkshire.
    +324
    In your location a properly aligned dish should be fine 99.9% of the time.
    There is a 'zone 2' Sky dish for poorer areas - it's slightly larger but I think you'd be wasting your money.
    A. Dork
  4. Del
    Del
    Nov 15, 2000
    736
    Berkshire
    +16
    stanleyntl
    I had an installer change my 45cm sky supplied satellite dish for a 90cm satellite dish using the sky quad LNB and the picture improvement was immediate.
    Although I did not suffer from total picture loss during storms before, the images did suffer from loss of quality. That is no longer the case since the change of dish.
    Del :)
  5. Bluevanman
    Bluevanman
    A standard size dish,properly aligned,with a working quad LNB, is perfectly adequate throughout most of the country. A zone 2 dish, ie the larger ones, are only required in 'fringe' areas, ie the far SW of England and Northern Scotland.
