Dish size
Discussion in 'Satellite TV, Sky TV & FreeSat' started by deanym, Apr 28, 2005.
  1. deanym
    deanym
    May 29, 2004
    1,786
    +141
    Would a 90cm dish give a better picture thru Sky than a minidish? Assuming both are set up correctly.
  2. Nick_UK
    Nick_UK
    Nov 13, 2004
    9,748
    103
    +270
    It's a digital system. If the signal is good enough to give a good quality signal (low bit error rate) then no increase in picture quality will result in using a bigger dish. In some cases a bigger dish can be a disadvantage.... bigger dishes are easier to knock off alignment.
    A good comparison is a telescope.... try looking at a star with a small telescope - the star will be quite easy to find, and moving the telescope will not completely lose the image. Now look at the same star through a more powerful telescope - you will have trouble finding the star, and moving the telescope a small amount will lose the star.
  3. deanym
    deanym
    May 29, 2004
    1,786
    +141
    Above seems to make sense (well other than the cantona-esque tosh about telescopes :rotfl: ) but just about all boxes that I've looked at - friends and familiy etc, are not on full signal strength or quality, therefore would a bigger dish allow these readings to become full and result in a higher quality picture?
  4. Nick_UK
    Nick_UK
    Nov 13, 2004
    9,748
    103
    +270
    If you are not going to read the replies properly, and only want to ridicule, then I doubt that you will get many more.
  5. deanym
    deanym
    May 29, 2004
    1,786
    +141
    I'll rephrase.
    Would a bigger dish allow the quality and signal stregth to increase to 100%?
  6. GGTVBD
    GGTVBD
    Feb 5, 2004
    3,365
    Bradford, West Yorkshire.
    +323
    Children - stop bickering! :rotfl:
    deanym,
    I thought Nick had explained things pretty well actually. He's clearly a knowledgeable guy and is always (or so I thought!!) helpful.
    My answer to your question - and don't take it personally - stop being so anal about signal strength. If you don't get any loss of signal you won't gain anything by using a 90cm dish.
    A. Dork
  7. deanym
    deanym
    May 29, 2004
    1,786
    +141
    Well thats the crux of the matter, the strength and quality are not at full stregth, and having an xde which are famed for being weak on sky sources, I was wondering of there is any way of improving this.
    Its certainly not anal to want to get the best out of a system.
    I'm moving house soon and I have in my possession a 90cm dish, lnb etc etc, so I don't have to rely on sky for installation.
  8. GGTVBD
    GGTVBD
    Feb 5, 2004
    3,365
    +323
    True......
    But you'll gain nothing by increasing the size of the dish.
    It doesn't matter what the levels are in the services menu - 50%, 75%, 100% - there will be no difference whatsoever in the picture quality.
    OK?
    A. Dork
  9. deanym
    deanym
    May 29, 2004
    1,786
    +141
    What about sound quality?
    Will there be more break up in bad weather with a larger dish?
  10. GGTVBD
    GGTVBD
    Feb 5, 2004
    3,365
    +323
    Nope.
    A. Dork :suicide: :suicide: :suicide: :suicide:
  11. deanym
    deanym
    May 29, 2004
    1,786
    +141
    Sorry for the rudimentary questions
    Bad weather - which will be more robust - mindish, or larger dish?
    Any advantages at all with a larger dish?
  12. Bluevanman
    Bluevanman
    None at all, unless you are moving to the far North of Scotland or the very Southwest of Cornwall. As a bit of an aside, most local authorities require you to have planning permission for a dish over 80cms.
  13. deanym
    deanym
    May 29, 2004
    1,786
    +141
    Planning permission - crikey.
    thanks for the info. :)
