Dish & LNB for Skystar 2
Discussion in 'TVs' started by Paul Alamo, Jan 21, 2004.
  1. Paul Alamo
    Paul Alamo
    If I purchased a Skystar 2 what dish and LNB do you recomend
    also I heard there was a problem with having two satellite dishes on your house as far as planning is concerned. Is this correct.
  2. aligebes
    aligebes
    Jan 2, 2004
    229
    Edinburgh, Scotland
    +3
    I'm using an old Channel master dish, with a Universal LNB, it is actually my dish from the old analogue Sky Service at 19.2deg east. As far as planning is concerned I believe this depends on the size of the dishes, and where you would set them up to get a strong reception(If it is likely to be in a prominently visible position from your neighbours)
