Dish in loft?
Discussion in 'Satellite TV, Sky TV & FreeSat' started by wfitzy, Feb 2, 2009.
Tags:
  1. wfitzy
    wfitzy
    Jul 15, 2008
    33
    not too sure if this is a daft question (probably is).
    Does anyone know if putting a dish in a loft would still pickup freesat channels. Already have a sky dish on front of house. Just thought it would make running cables easier.
    Again, sorry if this is a stupid question.
  2. Anoraknophobia
    Anoraknophobia
    Jan 13, 2009
    85
    11
    London
    +3
    No - This would not work.
    The satellite dish needs to have uninterrupted line of sight to the satellite. Any physical barriers and you won't get a signal.
  3. wfitzy
    wfitzy
    Jul 15, 2008
    33
    Thought it probably wouldnt work. Signals not able to get through roof etc.
  4. StevieBuck
    StevieBuck
    Jul 7, 2007
    3,728
    Aberdeen
    +674
    No it won't work.
    Are you planning to use that existing dish by moving it, or did you mean you're planning on getting another one?
  5. jwball
    jwball
    Mar 30, 2008
    333
    +7
    I think if it would work you wouldn't see many houses with massive dishes on the side of them.
  6. fernandez
    fernandez
    Jun 5, 2005
    6,039
    +995
    "# Loft dish: Very little chance of success. Signals do not travel well through slate or tile. If you have a loft window, or are prepared to replace some of your tiles either with thin perspex or microwave-transparent tiles, then there's a change of getting a signal"
    and have a look here Multimo dish
  7. Lunar Wolf
    Lunar Wolf
    Dec 9, 2008
    506
    +23
    only thing is you can put a TV ariel in the loft and it would work, but many houses havet them on the chimney anyway.
  8. beerhunter
    beerhunter
    Nov 9, 2005
    6,335
    Hampshire
    +740
    Not if you want Freeview. Freeview does not work with loft aerials for most people.
  9. Lunar Wolf
    Lunar Wolf
    Dec 9, 2008
    506
    +23
    probably, although it worked for me (but that was with a signal booster i've always used). I was pointing out the hole in the logic, lets not get too hung up on it.
  10. jwball
    jwball
    Mar 30, 2008
    333
    +7
    I don't have a chimney or an aerial.
    But I do have an empty loft ;)
