Dish angle and direction.
Discussion in 'Satellite TV, Sky TV & FreeSat' started by aimprod, Nov 12, 2003.
  1. aimprod
    aimprod
    Jan 19, 2003
    24
    East London
    Do any of you clever people out there know the correct angle and direction that the dish should be at. I live in London if that makes any difference.
  2. Chris Muriel
    Chris Muriel
    Jun 14, 2002
    7,108
    Manchester
    +713
    I assume you mean for $ky Digital although you didn't state that explicitly.
    The azimuth (horizontal plane) angle is 28 degrees east of due south. I forget the angle but it'll be about 23 degrees for a prime focus dish. Now most $ky dishes are offset types so your dish will be pointing more or less horizontally .
    If you start at this position, you should be able to find the signal as you carefully move the dish about and then peak for best signal.
    There is much better & more detailed info elsewhere.
    I bet Satcure's site has some good instructions.
    http://www.netcentral.co.uk/satcure/
    Chris Muriel, Manchester.
  3. aimprod
    aimprod
    Jan 19, 2003
    24
    East London
    Tanks Chris, yes I did mean sky digital, I'm moving and need to reinstall myself.
