Discrete Sound Proofing Options
Discussion in 'Home Cinema Building DIY' started by Seahorse, Aug 29, 2004.
  1. Seahorse
    Seahorse
    Jul 28, 2002
    141
    Southampton, Hants
    +3
    I want to deaden the noise fromt the front room somewhat, but do not want to go over the top with stud walls & insulation.
    Double glazing is being installed next week offering up the opportunity for change. I was thinking along the lines of fabric (is there such a thing) wallpaper, speaker stands, thick curtains and so on. Are speakers fixed to walls (brackets) a good or bad idea?
    I would welcome your suggestions... :lease:
  2. Londondecca
    Londondecca
    Dec 21, 2003
    2,081
    +96
    When you say deaden the sound, are you talking about minimising sound reflections etc or improving the sound proofing qualities of the room to minimise sound leakage.
  3. pemberto
    pemberto
    Oct 14, 2003
    502
    28
    Huntingdon
    +32
  4. Seahorse
    Seahorse
    Jul 28, 2002
    141
    Southampton, Hants
    +3
    Apologies for the tardy reply, this post disappeared from the forum when I posted it. It could be found by searching, but not on the main list. I was so peeved I though it had died.
    I have successfully upset the neighbour, and the wife works nights, so I'm trying to keep it in the front room...
    I'll check out the other thread in a moment... :)
    EDIT: Er, no I won't 404 on that linkage... :(
  5. pemberto
    pemberto
    Oct 14, 2003
    502
    28
    Huntingdon
    +32
    Mike,
    I don't know why that link did not work. Try this, perform a search on my user name permberto and have a look for at some of the threads I have posted on with regards to sound treatment.
    pemberto
  6. pemberto
    pemberto
    Oct 14, 2003
    502
    28
    Huntingdon
    +32
  7. Seahorse
    Seahorse
    Jul 28, 2002
    141
    Southampton, Hants
    +3
    Thanks mate, the site's useful, a search on your name lists this thread and no other LOL...;)
  8. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    26,563
    The Borders
    +3,027
    Seahorse
    Its sounds like decent headphones are in order - its nigh on impossible to 'keep sound in a room' in a modern house and if you have to turn the volume down low enough not to annoy the rest of the house you cant 'hear' your system.
    Attaching the speakers to your walls is likely to enhance the 'out of room' experience rather than diminish it :)
    If this guy gets it right he's minted - (if he isn't already!!!). See http://www.widescreenreview.com/attractions/os1.html
    Best regards
    Joe
  9. Seahorse
    Seahorse
    Jul 28, 2002
    141
    Southampton, Hants
    +3
    Bugger 'em then...LOL
