discrete sony tv codes ?
Discussion in 'Home Cinema Control & Remote Controls' started by jonnyv, Jul 3, 2004.
  1. jonnyv
    jonnyv
    Mar 31, 2002
    2,277
    48
    +52
    Im looking for a discrete code to turn off the internal speakers on my sony kv-32ls60u tv, remote rm-932.
    All the codes on remote central dont work, if i go into the menu and turn the speakers off that works (obviously) but when tv is turned off the settings are lost and speakers are back on again
    any ideas ?
    thanks
  2. KW1816
    KW1816
    Jun 14, 2002
    836
    Surrey
    +14
    Turn the volume down to 0 ?
    That's what I did with mine, the TV always remembers the last volume level so you only need to do it the once.
    Kevin.
  3. jonnyv
    jonnyv
    Mar 31, 2002
    2,277
    48
    +52
    the reason i want to turn off the speakers is that i need to use the phono outputs on the tv to hook up to my amp when using my gamecube, speakers have to be turned off for the phono outputs to work.
    However just ordered a scart lead with phono outputs, so will not need to turn off speakers.
