Discrete codes - how to use with a Pronto?
Discussion in 'Home Cinema Control & Remote Controls' started by prof yaffle, Nov 7, 2004.
  1. prof yaffle
    prof yaffle
    Jun 11, 2002
    40
    Amersham
    +5
    I've just bought a Pure Direct DAB tuner (the 702ES) & am trying to add it into my Pronto. I've got all the standard IR codes (remotecentral & some direct learning) - but can't find a source for the discrete codes, in particular On & Off. I emailed customer support... & they sent the following back:
    POWERON 0x11
    POWEROFF 0x09
    AM 0x02
    FM 0x0A
    DAB 0x12
    MUTEON 0x16
    MUTEOFF 0x1B
    Anyone got any suggestions how these would work in a Pronto?? The 'x' in code in particular is a bit confusing...
    Any help appreciated. Thks.
  2. mjn
    mjn
    May 24, 2001
    21,424
    Herts, England
    +8,981
    those codes look a bit short to me, but you can try them anyway.
