Discrete codes - how do I get 256 possibles (for Samsung AV receiver AV-R710)
Discussion in 'Home Cinema Control & Remote Controls' started by bmuirhead, Feb 3, 2009.
  1. bmuirhead
    bmuirhead
    Feb 3, 2009
    7
    I have spent 2 frustrating days trying to find a way of gemerating a full set of discrete codes for my Samsung AV receiver (AV-R710). I really need the codes for ON and OFF for my Harmony One!
    I have located and tried Makehex and IrPanels. I have read that the Samsung20 protocol is not used now by Samsung and they use NECx2. I can generate a CCF and load onto a Pocket PC to test.
    What I need to know is
    what protocol should I use? is it Samsung 20, NECx2 etc (or which irp file in makehex?)
    What device number should I use?
    If nobody knows - how can I find out? Or is there a much simpler way of generating discrete codes for my Samsung??
    thanks
    Bill
  2. logiciel
    logiciel
    Feb 2, 2008
    53,138
    UK
    +5,778
    If you want Logittech support to add new hex codes to your account they need to be in the format of 16 by 4 character numbers.
  3. clockworks
    clockworks
    Dec 7, 2005
    3,573
    West Country
    +297
    Have you asked this question on the "remote central" forums? Many of the guys there are professional AV installers who may be able to help. They also have a "discrete codes" forum.
    It's possible that discrete power codes don't exist for your TV - couldn't find any for my old Samsung LCD, or for my current Panasonic.
    If you find an solution, please post back.
  4. amorenod
    amorenod
    Sep 17, 2002
    483
    28
    +41
    For the love of God, if you ask in Remote Central Custom Installer subforum, don't dare to mention the hex codes are for a Harmony, or you will be raped and get about 20 answers, none with the solution.
  5. clockworks
    clockworks
    Dec 7, 2005
    3,573
    West Country
    +297
    Very good point - they don't like Harmonys on there. Best to say it's for a Pronto or PPC.
  6. richardbarman
    richardbarman
    Apr 25, 2005
    65
    Bill,
    Sumsung use the NEC protocol, so use this in the Make Hex. Samsung usually reserve code 98 and 99 for the power on and off discretes, and 01, or 02 for the power toggle, so try 98 and 99 first.
    If you post the learnt power toggle code here (in pronto format), then it's not too difficult to decode it, and check the NEC group code.
    Richard
  7. makitamark
    makitamark
    Sep 14, 2004
    251
    South Yorkshire
    +20
    How exactly can he post a learnt code from his harmony remote?
  8. bmuirhead
    bmuirhead
    Feb 3, 2009
    7
    I have installed a program called IR Server Suite and this has enabled me to get the hex codes for the power toggle button on my remote. I pasted this into IR Tool and it gave me the following
    Device: Raw/Unknown
    Carrier: 0079
    Raw: 005e 0046 1 1 0 0 0 0 1 0 1 1 0 0 1 0 1 0 1 0 0 0 0 0 0 0 0 0 1 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 0 0 0 0 0 0011 0692 005e 007d 0011 066c 005e 007d 0011 066c 005e 007d 0011 066c 005e 007d 0011 0a09
    The hex string was:
    0000 0079 003A 0000 005E 0046 0011 002B 0011 0029 0011 000F 0011 000F 0011 000F 0011 000E 0011 002B 0011 000F 0011 002B 0011 0029 0011 000F 0011 000F 0011 002B 0011 000E 0011 002B 0011 000F 0011 002B 0011 000F 0011 000F 0011 000F 0011 000F 000F 000F 0011 000F 0011 000F 0011 000F 0011 000E 0011 002B 0011 000F 0011 000F 0011 000F 000F 000F 0011 000F 0011 000F 0011 000F 0011 000F 0011 000E 0011 000F 0011 000F 0011 000F 0011 000F 0011 000E 0011 000F 0011 002B 0011 000F 0011 000F 000F 000F 0011 000F 0011 000F 0011 0692 005E 007D 0011 066C 005E 007D 0011 066C 005C 007D 0011 066C 005E 007D 0011 0A09
    Any ideas?
    thanks
    Bill
  9. makitamark
    makitamark
    Sep 14, 2004
    251
    South Yorkshire
    +20
    you're not using irtool properly, you need to use an additional file with the program, the hex you posted decodes as Teac-K protocol. do you want all 256 codes?
  10. makitamark
    makitamark
    Sep 14, 2004
    251
    South Yorkshire
    +20
    these are all the generated codes, note, power toggle is function zero.
    have fun!
    Device Code: 0.4 Function: 0
    0000 006D 0032 0002 0083 0042 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 066B 0083 0084 0010 066B
    Device Code: 0.4 Function: 1
    0000 006D 0032 0002 0083 0042 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 066B 0083 0084 0010 066B
    Device Code: 0.4 Function: 2
    0000 006D 0032 0002 0083 0042 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 066B 0083 0084 0010 066B
    Device Code: 0.4 Function: 3
    0000 006D 0032 0002 0083 0042 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 066B 0083 0084 0010 066B
    Device Code: 0.4 Function: 4
    0000 006D 0032 0002 0083 0042 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 066B 0083 0084 0010 066B
    Device Code: 0.4 Function: 5
    0000 006D 0032 0002 0083 0042 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 066B 0083 0084 0010 066B
    Device Code: 0.4 Function: 6
    0000 006D 0032 0002 0083 0042 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 066B 0083 0084 0010 066B
    Device Code: 0.4 Function: 7
    0000 006D 0032 0002 0083 0042 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 066B 0083 0084 0010 066B
    Device Code: 0.4 Function: 8
    0000 006D 0032 0002 0083 0042 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 066B 0083 0084 0010 066B
    Device Code: 0.4 Function: 9
    0000 006D 0032 0002 0083 0042 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 066B 0083 0084 0010 066B
    Device Code: 0.4 Function: 10
    0000 006D 0032 0002 0083 0042 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 066B 0083 0084 0010 066B
    Device Code: 0.4 Function: 11
    0000 006D 0032 0002 0083 0042 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0032 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 066B 0083 0084 0010 066B
    Device Code: 0.4 Function: 12
    0000 006D 0032 0002 0083 0042 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 066B 0083 0084 0010 066B
    Device Code: 0.4 Function: 13
    0000 006D 0032 0002 0083 0042 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 066B 0083 0084 0010 066B
    Device Code: 0.4 Function: 14
    0000 006D 0032 0002 0083 0042 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 066B 0083 0084 0010 066B
    Device Code: 0.4 Function: 15
    0000 006D 0032 0002 0083 0042 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0032 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 066B 0083 0084 0010 066B
    Device Code: 0.4 Function: 16
    0000 006D 0032 0002 0083 0042 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 066B 0083 0084 0010 066B
    Device Code: 0.4 Function: 17
    0000 006D 0032 0002 0083 0042 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 066B 0083 0084 0010 066B
    Device Code: 0.4 Function: 18
    0000 006D 0032 0002 0083 0042 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0032 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 066B 0083 0084 0010 066B
    Device Code: 0.4 Function: 19
    0000 006D 0032 0002 0083 0042 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 066B 0083 0084 0010 066B
    Device Code: 0.4 Function: 20
    0000 006D 0032 0002 0083 0042 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 066B 0083 0084 0010 066B
    Device Code: 0.4 Function: 21
    0000 006D 0032 0002 0083 0042 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 066B 0083 0084 0010 066B
    Device Code: 0.4 Function: 22
    0000 006D 0032 0002 0083 0042 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0032 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 066B 0083 0084 0010 066B
    Device Code: 0.4 Function: 23
    0000 006D 0032 0002 0083 0042 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0032 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 066B 0083 0084 0010 066B
    Device Code: 0.4 Function: 24
    0000 006D 0032 0002 0083 0042 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 066B 0083 0084 0010 066B
    Device Code: 0.4 Function: 25
    0000 006D 0032 0002 0083 0042 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 066B 0083 0084 0010 066B
    Device Code: 0.4 Function: 26
    0000 006D 0032 0002 0083 0042 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0032 0010 0032 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 066B 0083 0084 0010 066B
    Device Code: 0.4 Function: 27
    0000 006D 0032 0002 0083 0042 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 066B 0083 0084 0010 066B
    Device Code: 0.4 Function: 28
    0000 006D 0032 0002 0083 0042 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 066B 0083 0084 0010 066B
    Device Code: 0.4 Function: 29
    0000 006D 0032 0002 0083 0042 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 066B 0083 0084 0010 066B
    Device Code: 0.4 Function: 30
    0000 006D 0032 0002 0083 0042 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0032 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 066B 0083 0084 0010 066B
    Device Code: 0.4 Function: 31
    0000 006D 0032 0002 0083 0042 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0032 0010 0032 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 066B 0083 0084 0010 066B
    Device Code: 0.4 Function: 32
    0000 006D 0032 0002 0083 0042 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 066B 0083 0084 0010 066B
    Device Code: 0.4 Function: 33
    0000 006D 0032 0002 0083 0042 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0032 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 066B 0083 0084 0010 066B
    Device Code: 0.4 Function: 34
    0000 006D 0032 0002 0083 0042 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 066B 0083 0084 0010 066B
    Device Code: 0.4 Function: 35
    0000 006D 0032 0002 0083 0042 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 066B 0083 0084 0010 066B
    Device Code: 0.4 Function: 36
    0000 006D 0032 0002 0083 0042 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 066B 0083 0084 0010 066B
    Device Code: 0.4 Function: 37
    0000 006D 0032 0002 0083 0042 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0032 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 066B 0083 0084 0010 066B
    Device Code: 0.4 Function: 38
    0000 006D 0032 0002 0083 0042 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 066B 0083 0084 0010 066B
    Device Code: 0.4 Function: 39
    0000 006D 0032 0002 0083 0042 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 066B 0083 0084 0010 066B
    Device Code: 0.4 Function: 40
    0000 006D 0032 0002 0083 0042 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0032 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 066B 0083 0084 0010 066B
    Device Code: 0.4 Function: 41
    0000 006D 0032 0002 0083 0042 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0032 0010 0032 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 066B 0083 0084 0010 066B
    Device Code: 0.4 Function: 42
    0000 006D 0032 0002 0083 0042 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 066B 0083 0084 0010 066B
    Device Code: 0.4 Function: 43
    0000 006D 0032 0002 0083 0042 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 066B 0083 0084 0010 066B
    Device Code: 0.4 Function: 44
    0000 006D 0032 0002 0083 0042 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 066B 0083 0084 0010 066B
    Device Code: 0.4 Function: 45
    0000 006D 0032 0002 0083 0042 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 066B 0083 0084 0010 066B
    Device Code: 0.4 Function: 46
    0000 006D 0032 0002 0083 0042 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0032 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 066B 0083 0084 0010 066B
    Device Code: 0.4 Function: 47
    0000 006D 0032 0002 0083 0042 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0032 0010 0032 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 066B 0083 0084 0010 066B
    Device Code: 0.4 Function: 48
    0000 006D 0032 0002 0083 0042 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 066B 0083 0084 0010 066B
    Device Code: 0.4 Function: 49
    0000 006D 0032 0002 0083 0042 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 066B 0083 0084 0010 066B
    Device Code: 0.4 Function: 50
    0000 006D 0032 0002 0083 0042 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 066B 0083 0084 0010 066B
    Device Code: 0.4 Function: 51
    0000 006D 0032 0002 0083 0042 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 066B 0083 0084 0010 066B
    Device Code: 0.4 Function: 52
    0000 006D 0032 0002 0083 0042 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 066B 0083 0084 0010 066B
    Device Code: 0.4 Function: 53
    0000 006D 0032 0002 0083 0042 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 066B 0083 0084 0010 066B
    Device Code: 0.4 Function: 54
    0000 006D 0032 0002 0083 0042 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 066B 0083 0084 0010 066B
    Device Code: 0.4 Function: 55
    0000 006D 0032 0002 0083 0042 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0032 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0032 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 066B 0083 0084 0010 066B
    Device Code: 0.4 Function: 56
    0000 006D 0032 0002 0083 0042 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0032 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 066B 0083 0084 0010 066B
    Device Code: 0.4 Function: 57
    0000 006D 0032 0002 0083 0042 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0032 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 066B 0083 0084 0010 066B
    Device Code: 0.4 Function: 58
    0000 006D 0032 0002 0083 0042 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 066B 0083 0084 0010 066B
    Device Code: 0.4 Function: 59
    0000 006D 0032 0002 0083 0042 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0032 0010 0011 0010 0032 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 066B 0083 0084 0010 066B
    Device Code: 0.4 Function: 60
    0000 006D 0032 0002 0083 0042 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0032 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 066B 0083 0084 0010 066B
    Device Code: 0.4 Function: 61
    0000 006D 0032 0002 0083 0042 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 066B 0083 0084 0010 066B
    Device Code: 0.4 Function: 62
    0000 006D 0032 0002 0083 0042 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0032 0010 0032 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 066B 0083 0084 0010 066B
    Device Code: 0.4 Function: 63
    0000 006D 0032 0002 0083 0042 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0032 0010 0032 0010 0032 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0032 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 066B 0083 0084 0010 066B
    Device Code: 0.4 Function: 64
    0000 006D 0032 0002 0083 0042 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 066B 0083 0084 0010 066B
    Device Code: 0.4 Function: 65
    0000 006D 0032 0002 0083 0042 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 066B 0083 0084 0010 066B
    Device Code: 0.4 Function: 66
    0000 006D 0032 0002 0083 0042 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 066B 0083 0084 0010 066B
    Device Code: 0.4 Function: 67
    0000 006D 0032 0002 0083 0042 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 066B 0083 0084 0010 066B
    Device Code: 0.4 Function: 68
    0000 006D 0032 0002 0083 0042 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 066B 0083 0084 0010 066B
    Device Code: 0.4 Function: 69
    0000 006D 0032 0002 0083 0042 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 066B 0083 0084 0010 066B
    Device Code: 0.4 Function: 70
    0000 006D 0032 0002 0083 0042 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0032 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 066B 0083 0084 0010 066B
    Device Code: 0.4 Function: 71
    0000 006D 0032 0002 0083 0042 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 066B 0083 0084 0010 066B
    Device Code: 0.4 Function: 72
    0000 006D 0032 0002 0083 0042 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 066B 0083 0084 0010 066B
    Device Code: 0.4 Function: 73
    0000 006D 0032 0002 0083 0042 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 066B 0083 0084 0010 066B
    Device Code: 0.4 Function: 74
    0000 006D 0032 0002 0083 0042 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 066B 0083 0084 0010 066B
    Device Code: 0.4 Function: 75
    0000 006D 0032 0002 0083 0042 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 066B 0083 0084 0010 066B
    Device Code: 0.4 Function: 76
    0000 006D 0032 0002 0083 0042 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 066B 0083 0084 0010 066B
    Device Code: 0.4 Function: 77
    0000 006D 0032 0002 0083 0042 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 066B 0083 0084 0010 066B
    Device Code: 0.4 Function: 78
    0000 006D 0032 0002 0083 0042 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0032 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 066B 0083 0084 0010 066B
    Device Code: 0.4 Function: 79
    0000 006D 0032 0002 0083 0042 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0032 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 066B 0083 0084 0010 066B
    Device Code: 0.4 Function: 80
    0000 006D 0032 0002 0083 0042 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 066B 0083 0084 0010 066B
    Device Code: 0.4 Function: 81
    0000 006D 0032 0002 0083 0042 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 066B 0083 0084 0010 066B
    Device Code: 0.4 Function: 82
    0000 006D 0032 0002 0083 0042 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 066B 0083 0084 0010 066B
    Device Code: 0.4 Function: 83
    0000 006D 0032 0002 0083 0042 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 066B 0083 0084 0010 066B
    Device Code: 0.4 Function: 84
    0000 006D 0032 0002 0083 0042 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 066B 0083 0084 0010 066B
    Device Code: 0.4 Function: 85
    0000 006D 0032 0002 0083 0042 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0032 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 066B 0083 0084 0010 066B
    Device Code: 0.4 Function: 86
    0000 006D 0032 0002 0083 0042 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 066B 0083 0084 0010 066B
    Device Code: 0.4 Function: 87
    0000 006D 0032 0002 0083 0042 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0032 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 066B 0083 0084 0010 066B
    Device Code: 0.4 Function: 88
    0000 006D 0032 0002 0083 0042 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 066B 0083 0084 0010 066B
    Device Code: 0.4 Function: 89
    0000 006D 0032 0002 0083 0042 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0032 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 066B 0083 0084 0010 066B
    Device Code: 0.4 Function: 90
    0000 006D 0032 0002 0083 0042 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 066B 0083 0084 0010 066B
    Device Code: 0.4 Function: 91
    0000 006D 0032 0002 0083 0042 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 066B 0083 0084 0010 066B
    Device Code: 0.4 Function: 92
    0000 006D 0032 0002 0083 0042 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0032 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 066B 0083 0084 0010 066B
    Device Code: 0.4 Function: 93
    0000 006D 0032 0002 0083 0042 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0032 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 066B 0083 0084 0010 066B
    Device Code: 0.4 Function: 94
    0000 006D 0032 0002 0083 0042 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0032 0010 0032 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 066B 0083 0084 0010 066B
    Device Code: 0.4 Function: 95
    0000 006D 0032 0002 0083 0042 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0032 0010 0032 0010 0032 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 066B 0083 0084 0010 066B
    Device Code: 0.4 Function: 96
    0000 006D 0032 0002 0083 0042 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 066B 0083 0084 0010 066B
    Device Code: 0.4 Function: 97
    0000 006D 0032 0002 0083 0042 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 066B 0083 0084 0010 066B
    Device Code: 0.4 Function: 98
    0000 006D 0032 0002 0083 0042 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 066B 0083 0084 0010 066B
    Device Code: 0.4 Function: 99
    0000 006D 0032 0002 0083 0042 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0032 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 066B 0083 0084 0010 066B
    Device Code: 0.4 Function: 100
    0000 006D 0032 0002 0083 0042 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 066B 0083 0084 0010 066B
    Device Code: 0.4 Function: 101
    0000 006D 0032 0002 0083 0042 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0032 0010 0032 0010 0011 0010 0032 0010 0032 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 066B 0083 0084 0010 066B
    Device Code: 0.4 Function: 102
    0000 006D 0032 0002 0083 0042 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 066B 0083 0084 0010 066B
    Device Code: 0.4 Function: 103
    0000 006D 0032 0002 0083 0042 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 066B 0083 0084 0010 066B
    Device Code: 0.4 Function: 104
    0000 006D 0032 0002 0083 0042 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 066B 0083 0084 0010 066B
    Device Code: 0.4 Function: 105
    0000 006D 0032 0002 0083 0042 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 066B 0083 0084 0010 066B
    Device Code: 0.4 Function: 106
    0000 006D 0032 0002 0083 0042 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 066B 0083 0084 0010 066B
    Device Code: 0.4 Function: 107
    0000 006D 0032 0002 0083 0042 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 066B 0083 0084 0010 066B
    Device Code: 0.4 Function: 108
    0000 006D 0032 0002 0083 0042 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 066B 0083 0084 0010 066B
    Device Code: 0.4 Function: 109
    0000 006D 0032 0002 0083 0042 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0032 0010 0032 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 066B 0083 0084 0010 066B
    Device Code: 0.4 Function: 110
    0000 006D 0032 0002 0083 0042 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0032 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 066B 0083 0084 0010 066B
    Device Code: 0.4 Function: 111
    0000 006D 0032 0002 0083 0042 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0032 0010 0032 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 066B 0083 0084 0010 066B
    Device Code: 0.4 Function: 112
    0000 006D 0032 0002 0083 0042 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0032 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 066B 0083 0084 0010 066B
    Device Code: 0.4 Function: 113
    0000 006D 0032 0002 0083 0042 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0032 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 066B 0083 0084 0010 066B
    Device Code: 0.4 Function: 114
    0000 006D 0032 0002 0083 0042 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0032 0010 0032 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 066B 0083 0084 0010 066B
    Device Code: 0.4 Function: 115
    0000 006D 0032 0002 0083 0042 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 066B 0083 0084 0010 066B
    Device Code: 0.4 Function: 116
    0000 006D 0032 0002 0083 0042 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0032 0010 0011 0010 0032 0010 0032 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 066B 0083 0084 0010 066B
    Device Code: 0.4 Function: 117
    0000 006D 0032 0002 0083 0042 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 066B 0083 0084 0010 066B
    Device Code: 0.4 Function: 118
    0000 006D 0032 0002 0083 0042 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0032 0010 0011 0010 0032 0010 0032 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 066B 0083 0084 0010 066B
    Device Code: 0.4 Function: 119
    0000 006D 0032 0002 0083 0042 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0032 0010 0032 0010 0011 0010 0032 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 066B 0083 0084 0010 066B
    Device Code: 0.4 Function: 120
    0000 006D 0032 0002 0083 0042 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0032 0010 0032 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 066B 0083 0084 0010 066B
    Device Code: 0.4 Function: 121
    0000 006D 0032 0002 0083 0042 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0032 0010 0032 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 066B 0083 0084 0010 066B
    Device Code: 0.4 Function: 122
    0000 006D 0032 0002 0083 0042 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0032 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 066B 0083 0084 0010 066B
    Device Code: 0.4 Function: 123
    0000 006D 0032 0002 0083 0042 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0032 0010 0011 0010 0032 0010 0032 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 066B 0083 0084 0010 066B
    Device Code: 0.4 Function: 124
    0000 006D 0032 0002 0083 0042 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0032 0010 0032 0010 0032 0010 0032 0010 0011 0010 0032 0010 0032 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 066B 0083 0084 0010 066B
    Device Code: 0.4 Function: 125
    0000 006D 0032 0002 0083 0042 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0032 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 066B 0083 0084 0010 066B
    Device Code: 0.4 Function: 126
    0000 006D 0032 0002 0083 0042 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0032 0010 0032 0010 0032 0010 0032 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 066B 0083 0084 0010 066B
    Device Code: 0.4 Function: 127
    0000 006D 0032 0002 0083 0042 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0032 0010 0032 0010 0032 0010 0032 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 066B 0083 0084 0010 066B
    Device Code: 0.4 Function: 128
    0000 006D 0032 0002 0083 0042 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 066B 0083 0084 0010 066B
    Device Code: 0.4 Function: 129
    0000 006D 0032 0002 0083 0042 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 066B 0083 0084 0010 066B
    Device Code: 0.4 Function: 130
    0000 006D 0032 0002 0083 0042 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 066B 0083 0084 0010 066B
    Device Code: 0.4 Function: 131
    0000 006D 0032 0002 0083 0042 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0032 0010 0032 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 066B 0083 0084 0010 066B
    Device Code: 0.4 Function: 132
    0000 006D 0032 0002 0083 0042 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 066B 0083 0084 0010 066B
    Device Code: 0.4 Function: 133
    0000 006D 0032 0002 0083 0042 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 066B 0083 0084 0010 066B
    Device Code: 0.4 Function: 134
    0000 006D 0032 0002 0083 0042 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 066B 0083 0084 0010 066B
    Device Code: 0.4 Function: 135
    0000 006D 0032 0002 0083 0042 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 066B 0083 0084 0010 066B
    Device Code: 0.4 Function: 136
    0000 006D 0032 0002 0083 0042 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 066B 0083 0084 0010 066B
    Device Code: 0.4 Function: 137
    0000 006D 0032 0002 0083 0042 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0032 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 066B 0083 0084 0010 066B
    Device Code: 0.4 Function: 138
    0000 006D 0032 0002 0083 0042 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 066B 0083 0084 0010 066B
    Device Code: 0.4 Function: 139
    0000 006D 0032 0002 0083 0042 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0032 0010 0032 0010 0032 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 066B 0083 0084 0010 066B
    Device Code: 0.4 Function: 140
    0000 006D 0032 0002 0083 0042 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 066B 0083 0084 0010 066B
    Device Code: 0.4 Function: 141
    0000 006D 0032 0002 0083 0042 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 066B 0083 0084 0010 066B
    Device Code: 0.4 Function: 142
    0000 006D 0032 0002 0083 0042 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 066B 0083 0084 0010 066B
    Device Code: 0.4 Function: 143
    0000 006D 0032 0002 0083 0042 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0032 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0032 0010 0032 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 066B 0083 0084 0010 066B
    Device Code: 0.4 Function: 144
    0000 006D 0032 0002 0083 0042 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0032 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 066B 0083 0084 0010 066B
    Device Code: 0.4 Function: 145
    0000 006D 0032 0002 0083 0042 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 066B 0083 0084 0010 066B
    Device Code: 0.4 Function: 146
    0000 006D 0032 0002 0083 0042 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0032 0010 0032 0010 0032 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 066B 0083 0084 0010 066B
    Device Code: 0.4 Function: 147
    0000 006D 0032 0002 0083 0042 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 066B 0083 0084 0010 066B
    Device Code: 0.4 Function: 148
    0000 006D 0032 0002 0083 0042 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 066B 0083 0084 0010 066B
    Device Code: 0.4 Function: 149
    0000 006D 0032 0002 0083 0042 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 066B 0083 0084 0010 066B
    Device Code: 0.4 Function: 150
    0000 006D 0032 0002 0083 0042 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0032 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 066B 0083 0084 0010 066B
    Device Code: 0.4 Function: 151
    0000 006D 0032 0002 0083 0042 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0032 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 066B 0083 0084 0010 066B
    Device Code: 0.4 Function: 152
    0000 006D 0032 0002 0083 0042 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 066B 0083 0084 0010 066B
    Device Code: 0.4 Function: 153
    0000 006D 0032 0002 0083 0042 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 066B 0083 0084 0010 066B
    Device Code: 0.4 Function: 154
    0000 006D 0032 0002 0083 0042 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0032 0010 0032 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 066B 0083 0084 0010 066B
    Device Code: 0.4 Function: 155
    0000 006D 0032 0002 0083 0042 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 066B 0083 0084 0010 066B
    Device Code: 0.4 Function: 156
    0000 006D 0032 0002 0083 0042 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 066B 0083 0084 0010 066B
    Device Code: 0.4 Function: 157
    0000 006D 0032 0002 0083 0042 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 066B 0083 0084 0010 066B
    Device Code: 0.4 Function: 158
    0000 006D 0032 0002 0083 0042 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0032 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0032 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 066B 0083 0084 0010 066B
    Device Code: 0.4 Function: 159
    0000 006D 0032 0002 0083 0042 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0032 0010 0032 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0032 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 066B 0083 0084 0010 066B
    Device Code: 0.4 Function: 160
    0000 006D 0032 0002 0083 0042 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 066B 0083 0084 0010 066B
    Device Code: 0.4 Function: 161
    0000 006D 0032 0002 0083 0042 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0032 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 066B 0083 0084 0010 066B
    Device Code: 0.4 Function: 162
    0000 006D 0032 0002 0083 0042 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 066B 0083 0084 0010 066B
    Device Code: 0.4 Function: 163
    0000 006D 0032 0002 0083 0042 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 066B 0083 0084 0010 066B
    Device Code: 0.4 Function: 164
    0000 006D 0032 0002 0083 0042 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 066B 0083 0084 0010 066B
    Device Code: 0.4 Function: 165
    0000 006D 0032 0002 0083 0042 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 066B 0083 0084 0010 066B
    Device Code: 0.4 Function: 166
    0000 006D 0032 0002 0083 0042 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 066B 0083 0084 0010 066B
    Device Code: 0.4 Function: 167
    0000 006D 0032 0002 0083 0042 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 066B 0083 0084 0010 066B
    Device Code: 0.4 Function: 168
    0000 006D 0032 0002 0083 0042 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 066B 0083 0084 0010 066B
    Device Code: 0.4 Function: 169
    0000 006D 0032 0002 0083 0042 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0032 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 066B 0083 0084 0010 066B
    Device Code: 0.4 Function: 170
    0000 006D 0032 0002 0083 0042 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 066B 0083 0084 0010 066B
    Device Code: 0.4 Function: 171
    0000 006D 0032 0002 0083 0042 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 066B 0083 0084 0010 066B
    Device Code: 0.4 Function: 172
    0000 006D 0032 0002 0083 0042 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 066B 0083 0084 0010 066B
    Device Code: 0.4 Function: 173
    0000 006D 0032 0002 0083 0042 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 066B 0083 0084 0010 066B
    Device Code: 0.4 Function: 174
    0000 006D 0032 0002 0083 0042 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0032 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0032 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 066B 0083 0084 0010 066B
    Device Code: 0.4 Function: 175
    0000 006D 0032 0002 0083 0042 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0032 0010 0032 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0032 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 066B 0083 0084 0010 066B
    Device Code: 0.4 Function: 176
    0000 006D 0032 0002 0083 0042 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0032 0010 0011 0010 0032 0010 0032 0010 0032 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 066B 0083 0084 0010 066B
    Device Code: 0.4 Function: 177
    0000 006D 0032 0002 0083 0042 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0032 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 066B 0083 0084 0010 066B
    Device Code: 0.4 Function: 178
    0000 006D 0032 0002 0083 0042 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0032 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 066B 0083 0084 0010 066B
    Device Code: 0.4 Function: 179
    0000 006D 0032 0002 0083 0042 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 066B 0083 0084 0010 066B
    Device Code: 0.4 Function: 180
    0000 006D 0032 0002 0083 0042 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0032 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 066B 0083 0084 0010 066B
    Device Code: 0.4 Function: 181
    0000 006D 0032 0002 0083 0042 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 066B 0083 0084 0010 066B
    Device Code: 0.4 Function: 182
    0000 006D 0032 0002 0083 0042 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 066B 0083 0084 0010 066B
    Device Code: 0.4 Function: 183
    0000 006D 0032 0002 0083 0042 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0032 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 066B 0083 0084 0010 066B
    Device Code: 0.4 Function: 184
    0000 006D 0032 0002 0083 0042 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0032 0010 0032 0010 0011 0010 0032 0010 0032 0010 0032 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 066B 0083 0084 0010 066B
    Device Code: 0.4 Function: 185
    0000 006D 0032 0002 0083 0042 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0032 0010 0032 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 066B 0083 0084 0010 066B
    Device Code: 0.4 Function: 186
    0000 006D 0032 0002 0083 0042 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 066B 0083 0084 0010 066B
    Device Code: 0.4 Function: 187
    0000 006D 0032 0002 0083 0042 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0032 0010 0011 0010 0032 0010 0032 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 066B 0083 0084 0010 066B
    Device Code: 0.4 Function: 188
    0000 006D 0032 0002 0083 0042 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0032 0010 0032 0010 0032 0010 0011 0010 0032 0010 0032 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 066B 0083 0084 0010 066B
    Device Code: 0.4 Function: 189
    0000 006D 0032 0002 0083 0042 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0032 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0032 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 066B 0083 0084 0010 066B
    Device Code: 0.4 Function: 190
    0000 006D 0032 0002 0083 0042 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0032 0010 0032 0010 0032 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0032 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 066B 0083 0084 0010 066B
    Device Code: 0.4 Function: 191
    0000 006D 0032 0002 0083 0042 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0032 0010 0032 0010 0032 0010 0032 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 066B 0083 0084 0010 066B
    Device Code: 0.4 Function: 192
    0000 006D 0032 0002 0083 0042 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 066B 0083 0084 0010 066B
    Device Code: 0.4 Function: 193
    0000 006D 0032 0002 0083 0042 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 066B 0083 0084 0010 066B
    Device Code: 0.4 Function: 194
    0000 006D 0032 0002 0083 0042 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 066B 0083 0084 0010 066B
    Device Code: 0.4 Function: 195
    0000 006D 0032 0002 0083 0042 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0032 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 066B 0083 0084 0010 066B
    Device Code: 0.4 Function: 196
    0000 006D 0032 0002 0083 0042 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 066B 0083 0084 0010 066B
    Device Code: 0.4 Function: 197
    0000 006D 0032 0002 0083 0042 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0032 0010 0032 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 066B 0083 0084 0010 066B
    Device Code: 0.4 Function: 198
    0000 006D 0032 0002 0083 0042 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0032 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 066B 0083 0084 0010 066B
    Device Code: 0.4 Function: 199
    0000 006D 0032 0002 0083 0042 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0032 0010 0032 0010 0032 0010 0032 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 066B 0083 0084 0010 066B
    Device Code: 0.4 Function: 200
    0000 006D 0032 0002 0083 0042 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 066B 0083 0084 0010 066B
    Device Code: 0.4 Function: 201
    0000 006D 0032 0002 0083 0042 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0032 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 066B 0083 0084 0010 066B
    Device Code: 0.4 Function: 202
    0000 006D 0032 0002 0083 0042 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0032 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 066B 0083 0084 0010 066B
    Device Code: 0.4 Function: 203
    0000 006D 0032 0002 0083 0042 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0032 0010 0032 0010 0032 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 066B 0083 0084 0010 066B
    Device Code: 0.4 Function: 204
    0000 006D 0032 0002 0083 0042 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 066B 0083 0084 0010 066B
    Device Code: 0.4 Function: 205
    0000 006D 0032 0002 0083 0042 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0032 0010 0032 0010 0011 0010 0032 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 066B 0083 0084 0010 066B
    Device Code: 0.4 Function: 206
    0000 006D 0032 0002 0083 0042 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0032 0010 0011 0010 0032 0010 0032 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 066B 0083 0084 0010 066B
    Device Code: 0.4 Function: 207
    0000 006D 0032 0002 0083 0042 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0032 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0032 0010 0032 0010 0032 0010 0032 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 066B 0083 0084 0010 066B
    Device Code: 0.4 Function: 208
    0000 006D 0032 0002 0083 0042 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 066B 0083 0084 0010 066B
    Device Code: 0.4 Function: 209
    0000 006D 0032 0002 0083 0042 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 066B 0083 0084 0010 066B
    Device Code: 0.4 Function: 210
    0000 006D 0032 0002 0083 0042 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 066B 0083 0084 0010 066B
    Device Code: 0.4 Function: 211
    0000 006D 0032 0002 0083 0042 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 066B 0083 0084 0010 066B
    Device Code: 0.4 Function: 212
    0000 006D 0032 0002 0083 0042 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 066B 0083 0084 0010 066B
    Device Code: 0.4 Function: 213
    0000 006D 0032 0002 0083 0042 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 066B 0083 0084 0010 066B
    Device Code: 0.4 Function: 214
    0000 006D 0032 0002 0083 0042 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0032 0010 0032 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 066B 0083 0084 0010 066B
    Device Code: 0.4 Function: 215
    0000 006D 0032 0002 0083 0042 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0032 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 066B 0083 0084 0010 066B
    Device Code: 0.4 Function: 216
    0000 006D 0032 0002 0083 0042 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0032 0010 0011 0010 0032 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 066B 0083 0084 0010 066B
    Device Code: 0.4 Function: 217
    0000 006D 0032 0002 0083 0042 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0032 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 066B 0083 0084 0010 066B
    Device Code: 0.4 Function: 218
    0000 006D 0032 0002 0083 0042 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0032 0010 0032 0010 0032 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 066B 0083 0084 0010 066B
    Device Code: 0.4 Function: 219
    0000 006D 0032 0002 0083 0042 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 066B 0083 0084 0010 066B
    Device Code: 0.4 Function: 220
    0000 006D 0032 0002 0083 0042 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0032 0010 0032 0010 0011 0010 0032 0010 0032 0010 0032 0010 0011 0010 0032 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 066B 0083 0084 0010 066B
    Device Code: 0.4 Function: 221
    0000 006D 0032 0002 0083 0042 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0032 0010 0032 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 066B 0083 0084 0010 066B
    Device Code: 0.4 Function: 222
    0000 006D 0032 0002 0083 0042 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0032 0010 0032 0010 0032 0010 0011 0010 0032 0010 0032 0010 0032 0010 0032 0010 0032 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 066B 0083 0084 0010 066B
    Device Code: 0.4 Function: 223
    0000 006D 0032 0002 0083 0042 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0032 0010 0032 0010 0032 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 066B 0083 0084 0010 066B
    Device Code: 0.4 Function: 224
    0000 006D 0032 0002 0083 0042 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0032 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 066B 0083 0084 0010 066B
    Device Code: 0.4 Function: 225
    0000 006D 0032 0002 0083 0042 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0032 0010 0032 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 066B 0083 0084 0010 066B
    Device Code: 0.4 Function: 226
    0000 006D 0032 0002 0083 0042 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0032 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 066B 0083 0084 0010 066B
    Device Code: 0.4 Function: 227
    0000 006D 0032 0002 0083 0042 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0032 0010 0032 0010 0032 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 066B 0083 0084 0010 066B
    Device Code: 0.4 Function: 228
    0000 006D 0032 0002 0083 0042 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0032 0010 0032 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 066B 0083 0084 0010 066B
    Device Code: 0.4 Function: 229
    0000 006D 0032 0002 0083 0042 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0032 0010 0032 0010 0032 0010 0032 0010 0032 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 066B 0083 0084 0010 066B
    Device Code: 0.4 Function: 230
    0000 006D 0032 0002 0083 0042 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 066B 0083 0084 0010 066B
    Device Code: 0.4 Function: 231
    0000 006D 0032 0002 0083 0042 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0032 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 066B 0083 0084 0010 066B
    Device Code: 0.4 Function: 232
    0000 006D 0032 0002 0083 0042 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 066B 0083 0084 0010 066B
    Device Code: 0.4 Function: 233
    0000 006D 0032 0002 0083 0042 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0032 0010 0032 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 066B 0083 0084 0010 066B
    Device Code: 0.4 Function: 234
    0000 006D 0032 0002 0083 0042 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 066B 0083 0084 0010 066B
    Device Code: 0.4 Function: 235
    0000 006D 0032 0002 0083 0042 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0032 0010 0032 0010 0011 0010 0032 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 066B 0083 0084 0010 066B
    Device Code: 0.4 Function: 236
    0000 006D 0032 0002 0083 0042 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0032 0010 0011 0010 0032 0010 0032 0010 0032 0010 0011 0010 0032 0010 0032 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 066B 0083 0084 0010 066B
    Device Code: 0.4 Function: 237
    0000 006D 0032 0002 0083 0042 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0032 0010 0032 0010 0032 0010 0032 0010 0032 0010 0032 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 066B 0083 0084 0010 066B
    Device Code: 0.4 Function: 238
    0000 006D 0032 0002 0083 0042 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0032 0010 0032 0010 0011 0010 0032 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 066B 0083 0084 0010 066B
    Device Code: 0.4 Function: 239
    0000 006D 0032 0002 0083 0042 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0032 0010 0032 0010 0032 0010 0011 0010 0032 0010 0032 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 066B 0083 0084 0010 066B
    Device Code: 0.4 Function: 240
    0000 006D 0032 0002 0083 0042 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0032 0010 0032 0010 0032 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 066B 0083 0084 0010 066B
    Device Code: 0.4 Function: 241
    0000 006D 0032 0002 0083 0042 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0032 0010 0032 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 066B 0083 0084 0010 066B
    Device Code: 0.4 Function: 242
    0000 006D 0032 0002 0083 0042 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0032 0010 0032 0010 0032 0010 0032 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 066B 0083 0084 0010 066B
    Device Code: 0.4 Function: 243
    0000 006D 0032 0002 0083 0042 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0032 0010 0032 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 066B 0083 0084 0010 066B
    Device Code: 0.4 Function: 244
    0000 006D 0032 0002 0083 0042 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0032 0010 0032 0010 0032 0010 0032 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 066B 0083 0084 0010 066B
    Device Code: 0.4 Function: 245
    0000 006D 0032 0002 0083 0042 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 066B 0083 0084 0010 066B
    Device Code: 0.4 Function: 246
    0000 006D 0032 0002 0083 0042 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0032 0010 0011 0010 0032 0010 0032 0010 0032 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 066B 0083 0084 0010 066B
    Device Code: 0.4 Function: 247
    0000 006D 0032 0002 0083 0042 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0032 0010 0032 0010 0011 0010 0032 0010 0032 0010 0032 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 066B 0083 0084 0010 066B
    Device Code: 0.4 Function: 248
    0000 006D 0032 0002 0083 0042 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0032 0010 0032 0010 0032 0010 0032 0010 0032 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 066B 0083 0084 0010 066B
    Device Code: 0.4 Function: 249
    0000 006D 0032 0002 0083 0042 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0032 0010 0032 0010 0032 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 066B 0083 0084 0010 066B
    Device Code: 0.4 Function: 250
    0000 006D 0032 0002 0083 0042 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0032 0010 0032 0010 0032 0010 0032 0010 0011 0010 0032 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 066B 0083 0084 0010 066B
    Device Code: 0.4 Function: 251
    0000 006D 0032 0002 0083 0042 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0032 0010 0011 0010 0032 0010 0032 0010 0032 0010 0032 0010 0032 0010 0011 0010 0032 0010 0032 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 066B 0083 0084 0010 066B
    Device Code: 0.4 Function: 252
    0000 006D 0032 0002 0083 0042 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0032 0010 0032 0010 0032 0010 0032 0010 0032 0010 0032 0010 0032 0010 0032 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 066B 0083 0084 0010 066B
    Device Code: 0.4 Function: 253
    0000 006D 0032 0002 0083 0042 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0032 0010 0032 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 066B 0083 0084 0010 066B
    Device Code: 0.4 Function: 254
    0000 006D 0032 0002 0083 0042 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0032 0010 0032 0010 0032 0010 0032 0010 0032 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 066B 0083 0084 0010 066B
    Device Code: 0.4 Function: 255
    0000 006D 0032 0002 0083 0042 0010 0032 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0032 0010 0011 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0032 0010 0032 0010 0032 0010 0032 0010 0032 0010 0032 0010 0032 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0010 0011 0010 0032 0010 0011 0010 0011 0010 066B 0083 0084 0010 066B
  11. bmuirhead
    bmuirhead
    Feb 3, 2009
    7
    Hi makitamark
    Thank you very much for this!!
    I think I am almost there - but I have 3 questions:
    - What do I need to do to use irtool properly so that I can decode and generate new codes just like you did?
    - is there a way I can covert each code back to the learned format (like in my post) so I can use the 'blaster' in the IR Server Suite software on my PC to test each one?
    - are the full set of codes in pronto format? I converted them with IRpanels and loaded the CCF onto my Pocket PC, but I get an error when I press any of the generated buttons!
    Sorry for the questions but I want to test each code but I still have gaps in my knowledge ... I really do appreciate your help!
    thanks
    Bill
  12. bmuirhead
    bmuirhead
    Feb 3, 2009
    7
    OK I have cracked my first problem. I have found the modded version of IRTool (IRTool-Mod) and the additional file (decodeir). Got the correct answer of Teac-k. I ran it through MakeHex and got exactly the same set of function codes you gave me!
    So, I am quite pleased with that - would never have got there without your post though!
    Question still remains as to how I test out all the codes? I have downloaded 'IR Server Suite' as I have the Windows media center remote, receiver and blaster. Can I use this or maybe other software to test the codes?
    I also have an 2003 Pocket PC that does not seem to do the job. Maybe a bit too old and flakey!
    Bill
  13. makitamark
    makitamark
    Sep 14, 2004
    251
    South Yorkshire
    +20
    i take it from your reply you are having difficulty entering the codes into your software? these codes are clean generated codes and every IR software i know of will accept codes in this format. Pronto's can sometimes compress the codes into their own format - particularly RC5 codes and other software struggles with this compressed format, but the above codes should be no problem, i've not used the software you have since i have pronto's, MX's, RTI's amongst others, the programs that are used with them accept those codes perfectly.
  14. stoobie
    stoobie
    Jun 3, 2006
    444
    Exeter, Devon
    +78
    Not completely true, there is even a harmony thread on the site which may be of some use.
    Stoobie
  15. amorenod
    amorenod
    Sep 17, 2002
    483
    28
    +41
    We were talking about the CIs sub-forum.
    Don't get me wrong, I love to read the topics in there (the one about who owns the code on custom installs is very interesting) but post something about Harmonys and take your internet life into your hands.
