Discrete codes for Toshiba 28W8DB
Discussion in 'Home Cinema Control & Remote Controls' started by Coolhand, Jan 17, 2002.
  1. Coolhand
    Coolhand
    Jan 17, 2002
    61
    +8
    Does anyone have any discrete power on/off codes for the Toshiba 28W8DB TV?
    I've had a look on remotecentral but can't find any there.
    Are there any other sites I should look at for these codes?
    Do they exist or do Toshiba not do discrete power codes?
    Any help you can give will be much appreciated.
  2. KAO
    KAO
    I have a Toshiba TV too (3339 if memory serves me right). Toshiba equipment is what some refer to as TOADs...they have no discrete RC power on/off codes.
