discrete codes for sky plus ?
Discussion in 'Home Cinema Control & Remote Controls' started by nicke20, Oct 27, 2003.
  1. nicke20
    nicke20
    Oct 11, 2003
    874
    +13
    any one got them yet ??
    just power on and off
  2. Loada
    Loada
    Mar 4, 2003
    585
    Guisborough, North Yorkshire
    +48
    For ON, simply use the [Sky] button code
    For OFF, send the [Sky] button followed by a small delay, then the [POWER] button.
    Simple! No discretes required.
    :clap:
  3. nicke20
    nicke20
    Oct 11, 2003
    874
    +13
    Lol when I checked how I had done it with the old digibox it was the same way !! realy should have looked at my old pronto ccf before giving up so easily
    thanks for the pointer !!
  4. rnjones
    rnjones
    Nicke20, if you need a power off macro and you need to get it to work regardless of the State of the Sy + box. Do a Macro for the Sky button to switch it on followed by the power button. This ensures it is OFF.
    Rog
  5. nfordenfield
    nfordenfield
    Apr 9, 2001
    625
    19
    Kent
    Or better still macro sky button then off, this will definately turn it off, then ON should always work.
    The same work with my plasma, as the input button turns it on.
  6. Loada
    Loada
    Mar 4, 2003
    585
    +48
    Did anyone actually READ my post??? ;)
  7. nfordenfield
    nfordenfield
    Apr 9, 2001
    625
    19
    Kent
    Sorry Loada, i'd assume you would guess NO as we gave an alternative suggestion.
    Come on guys, anyone got the codes!?!?!
  8. SimonO
    SimonO
    Nov 4, 2002
    3,193
    71
    Hertfordshire
    +64
    They almost certainly don't exist...
