Discrete codes for Fusion FVRT100 (possible to generate from learnt codes?)
Discussion in 'Home Cinema Control & Remote Controls' started by rutteger, Dec 21, 2004.
  1. rutteger
    rutteger
    Apr 29, 2004
    452
    +7
    Trying to find discrete power codes for the Fusion FVRT100. I have succesfully learnt the remote commands using my pronto, however the power command is only a toggle.
    The power command in Pronto hex is
    0000 006c 0000 000a 0020 0020 0020 0020 0040 0040 0040 0020 0020 0040 0040 0020 0020 0040 0040 0040 0020 0020 0020 0cb5
    By eye the remainder of the commands follow a similar pattern. Hopefully someone can give me some pointers as to how to generate a complete list of all possible IR codes for this device.
  2. rutteger
    rutteger
    Apr 29, 2004
    452
    +7
    After getting some excellent assistance at remote central it would appear there are no discrete power codes for this device that I can find. Which is a shame.
