Discrete code opinion to Loewe Germany
Discussion in 'Home Cinema Control & Remote Controls' started by zoolap, Feb 19, 2002.
  1. zoolap
    zoolap
    Oct 2, 2001
    594
    Warwickshire
    +7
    I assume that most people using Prontos and related remotes are farmiliar with the remotecentral forum. I was reading an entry in the remote central forum by a guy called Stephen. He was looking for a list of RC5 code details for the Aconda. He says that he has got in touch with someone at Loewe UK who can get in touch with Loewe Germany to pass on comments about the lack of discrete codes on uk versions of tvs.
    The link is below:
    http://www.remotecentral.com/cgi-bin/mboard/rc-pronto/thread.cgi?17835
    Please help him out if you can. I would love to have dicrete function for my Vitros.
    Sorry if I have caused any inconvenience.
    Also should I post this in the tv section as well?
    Thanks.
  2. masopa
    masopa
    May 21, 2003
    94
    +17
    What is that guy's problem???? (Mike, whoever he is)
    Anyway, back to topic - I guess there was no joy in getting Loewe discrete codes???
  3. Gerbil
    Gerbil
    May 20, 2002
    268
    Newbury
    +23
    I have discrete on/off codes that work on an Aconda 9381 if thats any help?
  4. masopa
    masopa
    May 21, 2003
    94
    +17
    I'd be interested to give those a go - I have a Xelos, so there's no guarantee they'd be compatible, but I'd be interested to see the codes...
  5. kyle reece
    kyle reece
    i used to sell loewe tv's.
    they did use the same ir codes as goldstar tv sets !
    found this out by accident was demoing a goldstar tv & it worked the loewe sets
    ps. goldstar are now called LG
    hope this helps :smashin:
  6. Gerbil
    Gerbil
    May 20, 2002
    268
    Newbury
    +23
    I'll dig them out tonight when I get home and post them. On reflection I can't remember whether I ever found a true discrete ON code. I definitely have a discrete OFF and I think for ON I just used the OK followed by a few seconds pause and another OK which either switches the set on if it was off or leaves it in the same state if it was already on.
  7. Gerbil
    Gerbil
    May 20, 2002
    268
    Newbury
    +23
    Hopefully the formatting won't get messed up when I post this, but try this for off. As I said works on my Aconda.
    0000 0072 000c 0000 0020 0020 0040 0020 0020 0020 0020 0020 0020 0020 0020 0020 0020 0020 0020 0040 0020 0020 0040 0020 0020 0040 0020 0020
    Good luck...
  8. kwangomango
    kwangomango
    Jan 9, 2003
    856
    Kent
    +38
    Has anyone had any luck getting these discrete codes for the Q2500 chassis? I'm after Pronto hex codes for On,Off, AV selection and Aspect ratio selection.
    Cheers for any help.
  9. Gerbil
    Gerbil
    May 20, 2002
    268
    Newbury
    +23
    I've got the 9381 with a 2500 chassis and the above discrete off code works for me.
    As for the AV selection codes I think you'll just have to improvise.
    I use
    OK
    delay
    channel number
    delay
    OK
    From the AV channel selection screen reached by OK you should find that 1-5 select BBC1 etc. but the numbers above 5 will directly select the SCART socket inputs.
  10. kwangomango
    kwangomango
    Jan 9, 2003
    856
    Kent
    +38
    Woo hoo!!
    It has been slow and painfull but i have discovered that there are indeed discrete codes for switching the AV inputs. Currently on my Mimo i have discrete codes for AV2 and AV3. It is currently all i need but i may find the others if i can be bothered.
    The codes i have are "One For All" Key Magic codes but i am sure there is a conversion utility to create Pronto codes from them.
    AV2 = 593
    AV3 = 238
    I also have the discrete power off code which is 718.
    Hope this helps
