Disco Subs For Home Cinema Use????
Discussion in 'Subwoofers' started by contactadam2002, Jan 16, 2005.
  1. contactadam2002
    contactadam2002
    Jan 13, 2005
    74
  2. Nimby
    Nimby
    Jan 27, 2004
    9,204
    The Danish Bacon Factory
    +670
    Off the top of my head I would suggest that this sub has a very narrow, rather-humped frequency band with little extension below 40Hz. The visible horn loading is to increase output from the front of the driver. With the large ports below likely to be the mouth of a rather short bass horn working off the back of the driver.
    I could be completely wrong of course. There seemed to be no mention of frequency response. Which is a bit of a worry.
    My wild guess would be that even if it is suitable for it's intended PA purpose. It is completely unsuitable for HT/AV use in a typical room.
    Nimby
  3. contactadam2002
    contactadam2002
    Jan 13, 2005
    74
    K thanks for that mate. Actually Im not sure if the rear connections would be correct. Any DJ's out there. Still would like some more opinions people so keep ur answers coming please, oh and if you have any web sites that are normally hard to find could you please provide them. :lease:
  4. Mroizouk
    Mroizouk
    Jan 11, 2005
    336
    London
    I've heard those mackies, and they're quite good as PA but don't have the extension needed for proper AV sound. I think they've got speakon connections, and you'd need to source a decent and quiet-operating PA amp as well as an x-over. They also wouldn;t sound great in a living room-type situation as they're designed for use in bigger spaces.
    Of the subs on the site you provided, I imagine one of the Genelec units would be more suitable (esp. 7070A)
    You could also looking at getting a JBL or EAW cinema sub as used in multiplexes.
    For best AV sound and fewer complications though, you'd do better to get a sub for home use.
  5. contactadam2002
    contactadam2002
    Jan 13, 2005
    74
    Ah excellent, I had asked as one of my questions what subs were used in cinemas, and having checked out one of the sites they fit the profile...did you mean the JBL subs on that website...or diffrerent ones?
  6. Mandel
    Mandel
    The cinema I used to work at had one like the ones at the top of <a href="http://www.jblpro.com/cinema/subwoofers.htm">this page</a>. Lovely but maybe a bit big for home cinema :p
  7. contactadam2002
    contactadam2002
    Jan 13, 2005
    74
    Perfect..just the ones I was looking for. Wonder how much they cost though. Garuanteed sound quality. Do you know any particualr sites when they can be purchased from..or even cinema speakers?
  8. Nimby
    Nimby
    Jan 27, 2004
    9,204
    +670
  9. contactadam2002
    contactadam2002
    Jan 13, 2005
    74
    wow that was quick...I meant retailers though as I am currently on that page now. Internet retailers that maybe sell those speakers...so I have an idea of how much they cost (probably I guess about ten grand)
