Disc recommendations
Discussion in 'Blu-ray & DVD Players & Recorders' started by MikeNolan, Sep 10, 2005.
  1. MikeNolan
    MikeNolan
    Nov 28, 2004
    540
    Hereford
    Can anyone advise the best discs to buy for a Pana DMR-EH50. Either write one or re-write. Would it be a safe bet to go with Panasonic discs? Also, is there a source for the good discs that you can print directly on using inkjet?
  2. Oldjim
    Oldjim
    Oct 29, 2004
    77
  3. ROYOLD
    ROYOLD
    Jul 5, 2005
    3,898
    103
    Royton, Oldham. Lancs.
    +296
    I use the Datawrite 8x and 4x on my Panasonic E85 although I have also used Verbatim DVD-R.
    No coasters with any of these discs. The former were obtained from SVP (blankdiscshop). Also purchased
    spindles of 10 Ridisc DVD-RAM discs from the same outlet. These are cheaper than the Panasonic discs.
    Blankdiscshop also have some inkjet printable 2x
    DVD-R discs in spindles of 100. These may also work on your Panasonic. Intend purchasing some of these shortly.
