Disc Compatibility
Discussion in 'Blu-ray & DVD Players & Recorders' started by dsw182, Jul 17, 2005.
  1. dsw182
    dsw182
    Jun 8, 2003
    755
    UK
    +9
    Can anyone point me in the direction of a site which lists what discs are compatible with different players?
    I need to check a particular set will play a certain disc format.
  2. vonhosen
    vonhosen
    Jan 6, 2003
    1,835
    41
    London
    +13
  3. dsw182
    dsw182
    Jun 8, 2003
    755
    UK
    +9
    Great, thank you.
    I now have the problem of working out why my LG player won't play DVD-Rs, even though it should....
  4. vonhosen
    vonhosen
    Jan 6, 2003
    1,835
    41
    London
    +13
    Not all DVD-R are equal. Some brands are more compatible than others, so just because your player should play DVD-R's it may have gretaer success with some brands over others.
    Have you tried this particular DVD-R in other players you have access to & see if it works in them ?
  5. MarkE19
    MarkE19
    Aug 10, 2002
    17,132
    Rainham Essex
    +2,393
    Also sticking to a 1x or 2x burn speed will increase the compatability with many DVD players.
    And how was the DVD authored? Is it 100% DVD complient as some PC software allow you to change the settings that will make it unlikely to play in a standalone player.
    Mark.
  6. dsw182
    dsw182
    Jun 8, 2003
    755
    UK
    +9
    The discs (Samsung DVD-R, blue surface) do play on my Philips portable.
    I was using DVD Decrypter to burn the video files, so that may be a issue.
